I Have 3 phase system and in the settings I have set to peak shave to 20A and keep it there on every phase!
But Phase 1 it’s going up to 32-33 A?!?
The other 2 are staying around the 20 A
Which parameter is causing this!
Hi, did you managed to find the solution on this? I’m experiencing the same issue.. 3phase system using 3x MP II devices.. 2 of them (L1 and L2) are nicely supporting the extra load via AC-IN while the 3rd one (L3) is not. What could cause this?? I can’t figure it out ![]()
No unfortunately not. I reduced peak shaving so i got a beter margin so that the L1 fuse does not go…
I just recently reported some 1x MP2 in 3ph grid import limit issues in the new beta thread. Victron will take a look before releasing 3.70. Maybe it would make sense for you guys to try the new beta and report issues in the thread, so Victron can fix this issue also.
I have logged the issue under a new topic, see the link: Bug? :: Peak shaving feature in 3-phase MPII setup
