Using the Victron connect app show us your battery charge and engine shutdown settings and a status screen when this is happening for targetted advice.
For broad brush advice 90% or more problems are
Voltage drop due to.poor input wiring.
Voltage drop due to poor output wiring.
The Orion limiting current because it is too hot.
The alternator reducing output voltage because it is running hot.
Tje Orion should be able to work at 13.85V at the input as long as the shutdown voltage is set lower. The Orion reduces current if the input voltage falls to the shutdown voltage to stop the input voltage falling lower.
I am still at the same spot;
My Orion charging at 20-25 A’s only
Wonder if the battery internal BMS doing this?
The battery got a CAN port connection at the Cerbo GX
The MPPT got a VE Direct port at the Cerbo GX
The MPPT detect the BMS and display
«BMS controlled Yes»
If I turn this of; it will turn on again without my help
The MPPT is a 30A, but restricted at 20A
But even if I disable the MPPT, the Orion will not charge at full.
My Orion do not have a VE Direct port
But could it be that the BMS refuse the charge.?
The BMS should not be doing this as the Orion is not connected to anything to control it, it only works on input and output voltage. You have confirmed your input is 13.85V at battery and Orion. Use a meter to check the output voltage when charging, the Orion output and the battery should both be close to 14.2V. If you post screenshots of your settings and the status page when charging we can help more.
All wires used are 16mm2
Positiv and negativ leads;
2,5+2,5 =5 meters (start bat - Orion-Tr)
2,5+2,5 =5 meters (Orion-Tr - LiFePo4)
(Probably a bit less)
At 1500 rpm charging at 22-23A
I had 30A the first few weeks
Should be said that I did tweak the Orion-Tr parameters.
But I did not notice when the 5-7A was missed
Now looks like this when running;
Start battery voltage 13,98 Volt
(at the BMV-712)
Orion-Tr Input voltage 13,7 Volt
Loss in cable about 0,3 Volt loss
Orion-Tr Output voltage 13,7 Volt
Loss in cable 0,3 Volt
LiFePo4 battery intern voltage at 13,40 Volt
Victron Shunt voltage at 13,48 Volt
(similar to battery volt)
I have used my Thermo Camera without any surprices.
Pointing the camera at cables and terminals show temperatures at 25-30°C (outdoor at 17°C) no hot spots.
I can touch all wires without any problems.
It is in bulk but not at the full 30A, the output voltage is not limiting and the voltage drops are reasonable.
2 possibilities remain. The unit is overheating and throttling current but you have checked temperatures so unlikely. Or it is limiting current because you have the shutdown voltage set to 13.7V in engine shutdown detection.
Should mention that already at cold startup my Orion charging at reduced 20A.
Just now I did a 1 hrs test drive;
The datasheet says operating range -20 - 55°C
Measured again with my thermo camera;
The surface temp at aprox. 50°C
Is this within a reasonable range?
Also operating / running with a D-+
(control signal from alternator.)
