Hello, I have an Ekrano GX and 3 multi solar rs 6000.
At night the batteries dropped down to the state of charge limit which is currently set at 20% and in the morning when the solar starts generating instead of going all into the battery I would like it to supplement the current usage. The ESS settings. I only have three fields and I’ve seen a lot of other screenshots on the web showing a lot more variable items on other people set ups. Is there any way to enable the additional ESS settings? Or does anyone have any ideas how to make the system use? The solar generation prioritised over grid after the SOC limit has been reached? Thank you
