NodeRed Flow 0 Einspeisung über Heizstab Pufferspeicher
Hallo Community
Habe mir ein Flow zusammengebastelt der Bei 99% SOC und einer Pufferspeicher Temp ( Über LM335 ) unter 71 Grad Relais 2 vom Cerbo GX den Heizstab ansteuert ( der am AUX1 am Multiplus hängt und Über VeConfig Programierten Assistenten AcOut2 ansteuert ) , die Regelung wird aber ausser kraft gesetzt wenn Differenz der Zellen über 0,01V sind .
Somit kann ich verhindern das bei Zellendifferenz der Heizstab angesteuert wird bis Zellen Ungleichgewicht unter 0,01v ist.
Viel Spaß beim Testen
Manuel
        "id": "a787ea25.6e2f08",
        "type": "subflow",
        "name": "Difference",
        "info": "",
        "in": [
                "x": 60,
                "y": 120,
                "wires": [
                        "id": "c6c1a8f6.29f9a"
                        "id": "1fb5778c.9ddfd"
        "out": [
                "x": 1020,
                "y": 280,
                "wires": [
                        "id": "2796226d.63c97e",
                        "port": 0
        "outputLabels": [
            "reading",
            "difference"
        "id": "1fb5778c.9ddfd",
        "type": "function",
        "z": "a787ea25.6e2f08",
        "name": "Current Reading",
        "func": "//set a topic to join later\nmsg.topic = 'curr'; \n\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 220,
        "y": 180,
        "wires": [
                "b09d555.863fda8"
        "id": "c6c1a8f6.29f9a",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "1",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": true,
        "outputs": 1,
        "x": 205.75,
        "y": 327.0000305175781,
        "wires": [
                "4e42e8d7.cd4be"
        "id": "4e42e8d7.cd4be",
        "type": "function",
        "name": "Previous Reading",
        "func": "//set a topic to join later\nmsg.topic = 'prev'; \n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 527,
        "y": 326.00006103515625,
        "wires": [
                "b09d555.863fda8"
        "id": "b09d555.863fda8",
        "type": "join",
        "name": "Join each topic",
        "mode": "custom",
        "build": "object",
        "property": "payload",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "accumulate": true,
        "timeout": "",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 580,
        "y": 179.25003051757812,
        "wires": [
                "2796226d.63c97e"
        "type": "function",
        "func": "var c = msg.payload.curr - msg.payload.prev;\n\n// Calculate\nif (msg.topic == 'curr'){\n    msg.payload = c;\n    return msg;\n}\n\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1000,
        "y": 180,
        "wires": [
        "id": "da79a4c0.ef6ae",
        "type": "comment",
        "name": "input",
        "info": "Connect your Reading as msg.payload",
        "x": 70,
        "y": 80,
        "wires": []
        "id": "24a6c50a.bd7c62",
        "type": "comment",
        "name": "Delay 1msg / sec",
        "info": "to be able to get previous value \none message later",
        "x": 207.5,
        "y": 367.7500305175781,
        "wires": []
        "id": "3d3075e7.af4442",
        "type": "comment",
        "name": "Add Topic",
        "info": "",
        "x": 556.25,
        "y": 364.00006103515625,
        "wires": []
        "id": "21ff46d1.635dba",
        "type": "comment",
        "info": "",
        "x": 240,
        "y": 137.75003051757812,
        "wires": []
        "id": "c9aeb317.ef8668",
        "type": "comment",
        "name": "Calculate the Diff",
        "info": "",
        "x": 840,
        "wires": []
        "id": "64216738.bfae5",
        "type": "comment",
        "name": "Join / Combine msgs",
        "info": "",
        "x": 580,
        "wires": []
        "id": "2fb21af.6acaae6",
        "type": "comment",
        "name": "1st Out is Difference",
        "info": "",
        "x": 1230,
        "y": 280,
        "wires": []
        "id": "67dda7ad37b31550",
        "type": "tab",
        "label": "Solar Begranzung Pufferspeicher",
        "disabled": false,
        "info": "",
        "env": []
        "id": "04cbb6c2c70b06ed",
        "type": "group",
        "z": "67dda7ad37b31550",
        "name": "Differences Cell Start Flow",
        "style": {
            "label": true
        "nodes": [
            "d05cca8e.eaf878",
            "b7f4362d.727388",
            "a75ef7e0.831e6",
            "9d38a0f2c6f1e39b",
            "7b498d69b0a180a2",
            "deceb529e9c17240",
            "e2d876d9eb159621",
            "54d1e1c8627ef0f7",
            "0dcc9ee1f1bc1b00",
            "5a250d4ee669450b",
            "6cfebeecd142bc40"
        "x": 154,
        "y": 879,
        "w": 1732,
        "h": 242
        "id": "dc63c2fa37562d38",
        "type": "group",
        "name": "Solar limit owerflow into Ballon",
        "style": {
            "label": true
        "nodes": [
            "8d3e6c8e.8cbc9",
            "d08663fb.931a3",
            "f249379b.160858",
            "5e9c463a.27fc68",
            "37566273.473d5e",
            "a54e7199.6374",
            "2e209753.9b4fb8",
            "a535b1aa.3022a",
            "566cc94a.99f208",
            "243e481a.080958",
            "1370c306.727e1d",
            "af929e90e97d568b",
            "92414375d47ed037",
            "9d4ea051c90522ee",
            "5cbb7607b7529a84",
            "ae05d5ae777de073",
            "44d175d069852852",
            "4b4dd70141dc58d9",
            "93a19e1ef0b5e34c",
            "eb658cd1d02a864c",
            "5555ee0a6cdd2ab3",
            "1cfa28c1870aff17",
            "b2db954a1ea97ed9",
            "2a5f0a576b0a424b",
            "5e9acba5d747a390",
            "a7a921db4a4ddc7c"
        "x": 154,
        "y": 79,
        "w": 1352,
        "h": 762
        "id": "b2db954a1ea97ed9",
        "type": "junction",
        "g": "dc63c2fa37562d38",
        "x": 580,
        "y": 240,
        "wires": [
                "2e209753.9b4fb8"
        "id": "2a5f0a576b0a424b",
        "type": "junction",
        "x": 520,
        "y": 380,
        "wires": [
                "a54e7199.6374"
        "id": "8d3e6c8e.8cbc9",
        "type": "inject",
        "name": "99%",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Battery_SOC",
        "payload": "99",
        "payloadType": "num",
        "x": 410,
        "y": 120,
        "wires": [
                "b2db954a1ea97ed9"
        "id": "d08663fb.931a3",
        "type": "inject",
        "name": "97%",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Battery SOC",
        "payload": "97",
        "x": 410,
        "y": 160,
        "wires": [
                "b2db954a1ea97ed9"
        "id": "f249379b.160858",
        "type": "debug",
        "name": "Trigger the thing?",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1170,
        "y": 600,
        "wires": []
        "id": "5e9c463a.27fc68",
        "type": "inject",
        "name": "72 C°",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Pufferspeicher_Temp",
        "payload": "72",
        "x": 410,
        "y": 360,
        "wires": [
                "2a5f0a576b0a424b"
        "id": "37566273.473d5e",
        "type": "inject",
        "name": "70 C°",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "payload": "70",
        "x": 410,
        "y": 400,
        "wires": [
                "2a5f0a576b0a424b"
        "id": "a54e7199.6374",
        "type": "change",
        "name": "Pufferspeicher_Temp",
        "rules": [
                "t": "set",
                "p": "Pufferspeicher_Temp",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1000,
        "y": 460,
        "wires": [
                "a7a921db4a4ddc7c"
        "id": "2e209753.9b4fb8",
        "type": "change",
        "name": "set Battery SOC",
        "rules": [
                "t": "set",
                "p": "Battery_SOC",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1140,
        "y": 240,
        "wires": [
                "566cc94a.99f208"
        "id": "a535b1aa.3022a",
        "type": "link in",
        "name": "Humidity Workflow",
        "links": [
            "566cc94a.99f208",
            "a7a921db4a4ddc7c"
        "x": 345,
        "y": 740,
        "wires": [
                "5e9acba5d747a390"
        "id": "566cc94a.99f208",
        "type": "link out",
        "name": "Batery SOC",
        "mode": "link",
        "links": [
            "a535b1aa.3022a"
        "x": 1255,
        "y": 240,
        "wires": []
        "id": "243e481a.080958",
        "type": "comment",
        "name": "Workflow",
        "info": "",
        "x": 240,
        "y": 600,
        "wires": []
        "id": "1370c306.727e1d",
        "type": "comment",
        "name": "on Pufferspeicher Temp",
        "info": "",
        "x": 280,
        "y": 660,
        "wires": []
        "id": "af929e90e97d568b",
        "type": "comment",
        "name": "Battery_SOC",
        "info": "",
        "x": 250,
        "y": 120,
        "wires": []
        "id": "92414375d47ed037",
        "type": "comment",
        "info": "",
        "x": 280,
        "y": 320,
        "wires": []
        "id": "9d4ea051c90522ee",
        "type": "victron-input-temperature",
        "service": "com.victronenergy.temperature/20",
        "path": "/Temperature",
        "serviceObj": {
            "name": "Pufferspeicher"
        "pathObj": {
            "type": "float",
            "name": "Temperature (°C)"
        "name": "Pufferspeicher",
        "onlyChanges": true,
        "roundValues": "0",
        "x": 420,
        "y": 460,
        "wires": [
        "id": "5cbb7607b7529a84",
        "type": "victron-input-system",
        "service": "com.victronenergy.system/0",
        "path": "/Dc/Battery/Soc",
        "serviceObj": {
            "name": "Venus system"
        "pathObj": {
            "type": "float",
            "name": "Battery State of Charge (%)"
        "name": "Battery SOC",
        "onlyChanges": false,
        "x": 410,
        "y": 240,
        "wires": [
        "id": "ae05d5ae777de073",
        "type": "change",
        "name": "",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "to": "1",
                "tot": "num"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "to": "0",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1030,
        "y": 740,
        "wires": [
                "44d175d069852852"
        "id": "44d175d069852852",
        "type": "victron-output-relay",
        "path": "/Relay/1/State",
        "serviceObj": {
            "name": "Venus device"
        "pathObj": {
            "type": "enum",
            "name": "Venus relay 2 state",
            "enum": {
                "0": "Open",
                "1": "Closed"
            "writable": true
        "initial": "",
        "name": "Relay 2 Water Temp heater",
        "x": 1360,
        "y": 740,
        "wires": []
        "id": "4b4dd70141dc58d9",
        "type": "victron-input-relay",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "enum": {
                "0": "Open",
                "1": "Closed"
        "initial": "",
        "name": "Relay 2 State",
        "x": 390,
        "y": 800,
        "wires": [
                "eb658cd1d02a864c"
        "id": "93a19e1ef0b5e34c",
        "type": "mqtt out",
        "name": "Relay 2",
        "topic": "Relay 2 State",
        "qos": "2",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "broker": "292856c50555893c",
        "x": 900,
        "y": 800,
        "wires": []
        "id": "eb658cd1d02a864c",
        "type": "rbe",
        "name": "Relay Message",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "1",
        "x": 600,
        "y": 800,
        "wires": [
                "93a19e1ef0b5e34c"
        "id": "5555ee0a6cdd2ab3",
        "type": "rbe",
        "name": "Block unless value Change",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "1",
        "x": 660,
        "y": 460,
        "wires": [
                "a54e7199.6374"
        "id": "1cfa28c1870aff17",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "topi": "1",
        "x": 860,
        "y": 240,
        "wires": [
                "2e209753.9b4fb8"
        "id": "d05cca8e.eaf878",
        "type": "subflow:a787ea25.6e2f08",
        "g": "04cbb6c2c70b06ed",
        "x": 980,
        "y": 1040,
        "wires": [
                "deceb529e9c17240"
        "id": "b7f4362d.727388",
        "type": "comment",
        "name": "Difference node is a subflow",
        "info": "Open and Edit Template to see details",
        "x": 800,
        "y": 960,
        "wires": []
        "id": "a75ef7e0.831e6",
        "type": "counter",
        "name": "",
        "init": 0,
        "step": "1",
        "lower": "",
        "upper": "",
        "mode": "increment",
        "outputs": 1,
        "x": 800,
        "y": 1040,
        "wires": [
                "d05cca8e.eaf878"
        "id": "9d38a0f2c6f1e39b",
        "type": "victron-input-ess",
        "service": "com.victronenergy.battery/512",
        "path": "/System/MaxCellVoltage",
        "serviceObj": {
            "name": "CAN-SMARTBMS-BAT"
        "pathObj": {
            "type": "integer",
            "name": "Maximum battery cell voltage"
        "name": "",
        "x": 380,
        "y": 1020,
        "wires": [
                "a75ef7e0.831e6"
        "id": "7b498d69b0a180a2",
        "path": "/System/MinCellVoltage",
        "serviceObj": {
        "pathObj": {
            "type": "integer",
            "name": "Minimum battery cell voltage"
        "name": "",
        "x": 380,
        "y": 1080,
        "wires": [
                "a75ef7e0.831e6"
        "id": "deceb529e9c17240",
        "type": "switch",
        "name": "Cell Diff",
        "rules": [
                "t": "btwn",
                "v": "0.002",
                "vt": "num",
                "v2": "0.010",
                "v2t": "num"
                "t": "btwn",
                "v": "0.011",
                "vt": "num",
                "v2": "0.04",
                "v2t": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1140,
        "y": 1040,
        "wires": [
                "0dcc9ee1f1bc1b00"
                "54d1e1c8627ef0f7"
        "id": "e2d876d9eb159621",
        "type": "debug",
        "name": "debug 22",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 1780,
        "y": 920,
        "wires": []
        "id": "54d1e1c8627ef0f7",
        "type": "range",
        "minin": "0.001",
        "maxin": "0.01",
        "minout": "5",
        "maxout": "5",
        "action": "scale",
        "round": false,
        "name": "Up To 10 Diff",
        "x": 1350,
        "y": 1060,
        "wires": [
                "5a250d4ee669450b"
        "id": "0dcc9ee1f1bc1b00",
        "type": "range",
        "minin": "0.011",
        "maxin": "0.04",
        "minout": "10",
        "maxout": "10",
        "action": "scale",
        "round": false,
        "name": "Over 10 Diff",
        "x": 1350,
        "y": 1020,
        "wires": [
                "5a250d4ee669450b"
        "id": "5e9acba5d747a390",
        "type": "function",
        "name": "Check Battrery SOC and Pufferspeicher Temp & Cell Diff",
        "func": "var Pufferspeicher_Temp = flow.get('Pufferspeicher_Temp')\nvar Battery_SOC = flow.get('Battery_SOC')\nvar Cell_Diff = flow.get('Cell_Diff')\n\nvar minTemp = 71;\nvar minSOC = 98;\nvar minDiff = 9;\n\n// Check Levels\nif(Pufferspeicher_Temp < minTemp && Battery_SOC > minSOC && Cell_Diff > minDiff){\n    msg.payload = true;\n}else{\n    msg.payload = false;\n}\n\nreturn msg\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 740,
        "wires": [
                "ae05d5ae777de073",
                "f249379b.160858"
        "id": "5a250d4ee669450b",
        "type": "change",
        "name": "Cell_Diff",
        "rules": [
                "t": "set",
                "p": "Cell_Diff",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1560,
        "y": 1040,
        "wires": [
                "e2d876d9eb159621"
        "id": "6cfebeecd142bc40",
        "type": "comment",
        "name": "Difference >10 Balancing On",
        "info": "",
        "x": 1260,
        "y": 960,
        "wires": []
        "id": "a7a921db4a4ddc7c",
        "type": "link out",
        "mode": "link",
        "links": [
            "a535b1aa.3022a"
        "x": 1175,
        "y": 460,
        "wires": []
        "id": "292856c50555893c",
        "type": "mqtt-broker",
        "name": "Homey",
        "broker": "192.168.188.119",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
hallo,
man kann das zwar so machen, leider funktioniert die loesung mit den einstellungen nicht sehr zufriedenstellens.
ich habe einen e-heizkessel mit 9 kW in 3 kW stufen, den ich ab einem einstellbaren soc (meistens irgendwo zwischen 80 und 90%, moeglichst unter 90%, da mein soc gerne mal von 88-90% auf 100% springt) soviel pv-leistung wie moeglich zum heizen benutze. meistens hat der heizungskreislauf dann am nachmittag seine solltemperatur (wird ebenfalls ueber node-red geregelt, mit einer toleranz bin ca. 5 grad) erreicht, so dass der akku noch voll geladen wird. ausserdem wird dabei auch ueberwacht, ob der wechselrichter in ueberlast geht und die heizung notfalls abgeschaltet.
die steuerung ist natuerlich wesentlich aufwendiger, da sowohl vor- als auch ruecklauftemperatur in die reglung eingehen und die aktuelle belastung des wechselrichters auf den einzelnen phasen. eine zeitverzoegerung ist ebenfalls eingebaut, sowohl fuer das zuschalten der einzelnen stufen als auch das abschalten. auch die akkuleistung und pv-leistung sowie der betriebsmodus der laderegler wird mit verarbeitet.
tschuess
