Commande Relais 2 par NodeRed
Bonjour
J’ai réussi a faire un Flow dans NodeRed pour éviter d’injecter le surplus en commandant une anode dans mon ballon tampon par le biais de la sortie ACOut2
J’ai créée deux condition d’activation désactivation SOC et deux pour la temperature ballon .
mais j’ai le problème que ci je ne fait pas un loop avec une node mqtt le relais 2 du GX fait du marche arrêt en permanence !
        "id": "67dda7ad37b31550",
        "type": "tab",
        "label": "Solar Begranzung Pufferspeicher",
        "disabled": false,
        "info": "",
        "env": []
        "id": "b2db954a1ea97ed9",
        "type": "junction",
        "z": "67dda7ad37b31550",
        "x": 420,
        "y": 60,
        "wires": [
                "2e209753.9b4fb8"
        "id": "2a5f0a576b0a424b",
        "type": "junction",
        "x": 400,
        "y": 300,
        "wires": [
                "a54e7199.6374"
        "id": "8d3e6c8e.8cbc9",
        "type": "inject",
        "name": "99%",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Battery_SOC",
        "payload": "99",
        "payloadType": "num",
        "x": 290,
        "y": 40,
        "wires": [
                "b2db954a1ea97ed9"
        "id": "d08663fb.931a3",
        "type": "inject",
        "name": "90%",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Battery SOC",
        "payload": "90",
        "x": 290,
        "y": 80,
        "wires": [
                "b2db954a1ea97ed9"
        "id": "f249379b.160858",
        "type": "debug",
        "name": "Trigger the thing?",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1130,
        "y": 580,
        "wires": []
        "id": "5e9c463a.27fc68",
        "type": "inject",
        "name": "78 C°",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Pufferspeicher_Temp",
        "payload": "78",
        "x": 290,
        "y": 280,
        "wires": [
                "2a5f0a576b0a424b"
        "id": "37566273.473d5e",
        "type": "inject",
        "name": "70 C°",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "payload": "70",
        "x": 290,
        "y": 320,
        "wires": [
                "2a5f0a576b0a424b"
        "id": "a54e7199.6374",
        "type": "change",
        "name": "Pufferspeicher_Temp",
        "rules": [
                "t": "set",
                "p": "Pufferspeicher_Temp",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 620,
        "y": 380,
        "wires": [
                "415e4fa7.4acc8"
        "id": "415e4fa7.4acc8",
        "type": "debug",
        "name": "Temp",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 870,
        "y": 380,
        "wires": []
        "id": "cfb9c3af.f6f99",
        "type": "debug",
        "name": "Battery SOC",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 890,
        "y": 160,
        "wires": []
        "id": "49318b1c.5960f4",
        "type": "function",
        "name": "Check Battrery SOC and Pufferspeicher Temp",
        "func": "var Pufferspeicher_Temp = flow.get('Pufferspeicher_Temp')\nvar Battery_SOC = flow.get('Battery_SOC')\n\nvar minTemp = 71;\nvar minSOC = 98;\n\n// Check Levels\nif(Pufferspeicher_Temp < minTemp && Battery_SOC > minSOC){\n    msg.payload = true;\n}else{\n    msg.payload = false;\n}\n\nreturn msg\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 480,
        "y": 660,
        "wires": [
                "ae05d5ae777de073"
        "id": "2e209753.9b4fb8",
        "type": "change",
        "name": "set Battery SOC",
        "rules": [
                "t": "set",
                "p": "Battery_SOC",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 580,
        "y": 160,
        "wires": [
                "cfb9c3af.f6f99",
                "566cc94a.99f208"
        "id": "a535b1aa.3022a",
        "type": "link in",
        "name": "Humidity Workflow",
        "links": [
            "566cc94a.99f208"
        "x": 225,
        "y": 660,
        "wires": [
                "49318b1c.5960f4"
        "id": "566cc94a.99f208",
        "type": "link out",
        "name": "Humidity",
        "links": [
            "a535b1aa.3022a"
        "x": 705,
        "y": 200,
        "wires": []
        "id": "243e481a.080958",
        "type": "comment",
        "name": "Workflow",
        "info": "",
        "x": 120,
        "y": 520,
        "wires": []
        "id": "1370c306.727e1d",
        "type": "comment",
        "name": "on Pufferspeicher Temp",
        "info": "",
        "x": 160,
        "y": 580,
        "wires": []
        "id": "af929e90e97d568b",
        "type": "comment",
        "name": "Battery_SOC",
        "info": "",
        "x": 130,
        "y": 40,
        "wires": []
        "id": "92414375d47ed037",
        "type": "comment",
        "info": "",
        "x": 160,
        "y": 240,
        "wires": []
        "id": "9d4ea051c90522ee",
        "type": "victron-input-temperature",
        "service": "com.victronenergy.temperature/20",
        "path": "/Temperature",
        "serviceObj": {
            "name": "Pufferspeicher"
        "pathObj": {
            "type": "float",
            "name": "Temperature (°C)"
        "name": "Pufferspeicher",
        "onlyChanges": true,
        "roundValues": "0",
        "x": 300,
        "y": 380,
        "wires": [
                "a54e7199.6374"
        "id": "5cbb7607b7529a84",
        "type": "victron-input-system",
        "service": "com.victronenergy.system/0",
        "path": "/Dc/Battery/Soc",
        "serviceObj": {
            "name": "Venus system"
        "pathObj": {
            "type": "float",
            "name": "Battery State of Charge (%)"
        "onlyChanges": false,
        "x": 290,
        "y": 160,
        "wires": [
                "2e209753.9b4fb8"
        "id": "ae05d5ae777de073",
        "type": "change",
        "name": "",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "to": "1",
                "tot": "num"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "to": "0",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 850,
        "y": 660,
        "wires": [
                "44d175d069852852",
                "f249379b.160858"
        "id": "44d175d069852852",
        "type": "victron-output-relay",
        "path": "/Relay/1/State",
        "serviceObj": {
            "name": "Venus device"
        "pathObj": {
            "type": "enum",
            "name": "Venus relay 2 state",
            "enum": {
                "0": "Open",
                "1": "Closed"
            "writable": true
        "initial": "",
        "name": "Relay 2 Water Temp heater",
        "x": 1180,
        "y": 660,
        "wires": []
        "id": "4b4dd70141dc58d9",
        "type": "victron-input-relay",
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "enum": {
                "0": "Open",
                "1": "Closed"
        "initial": "",
        "name": "Relay 2 State",
        "x": 870,
        "y": 720,
        "wires": [
                "57093b14d5f9cbb4"
        "id": "c9fe904c87e463f9",
        "type": "mqtt in",
        "name": "",
        "topic": "Relay 2 On Off",
        "qos": "2",
        "datatype": "auto-detect",
        "broker": "bcd76438d8aaced3",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 860,
        "y": 580,
        "wires": [
                "44d175d069852852"
        "id": "57093b14d5f9cbb4",
        "type": "mqtt out",
        "name": "",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 1100,
        "y": 720,
        "wires": []
        "id": "bcd76438d8aaced3",
        "type": "mqtt-broker",
        "name": "SOLAR",
        "broker": "192.168.188.119",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
J’ai trouver le problème .
Javais programmée la sortie 0 du Fonction Node en A/Z aulieu du 0/9 :wink:
voici le code sans erreur avec message MQTT de changement de statut du relais
        "type": "tab",
        "disabled": false,
        "info": "",
        "env": []
        "type": "junction",
        "x": 420,
        "y": 60,
        "wires": [
                "2e209753.9b4fb8"
        "type": "junction",
        "x": 400,
        "y": 300,
        "wires": [
                "a54e7199.6374"
        "type": "inject",
        "name": "99%",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "payload": "99",
        "x": 290,
        "y": 40,
        "wires": [
                "b2db954a1ea97ed9"
        "type": "inject",
        "name": "90%",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "payload": "90",
        "x": 290,
        "y": 80,
        "wires": [
                "b2db954a1ea97ed9"
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 1130,
        "y": 580,
        "wires": []
        "type": "inject",
        "name": "78 C°",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "payload": "78",
        "x": 290,
        "y": 280,
        "wires": [
                "2a5f0a576b0a424b"
        "type": "inject",
        "name": "70 C°",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "payload": "70",
        "x": 290,
        "y": 320,
        "wires": [
                "2a5f0a576b0a424b"
        "type": "change",
        "rules": [
                "t": "set",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 620,
        "y": 380,
        "wires": [
        "type": "function",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 480,
        "y": 660,
        "wires": [
                "ae05d5ae777de073"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "Battery_SOC",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 580,
        "y": 160,
        "wires": [
                "566cc94a.99f208"
        "type": "link in",
        "links": [
            "566cc94a.99f208"
        "x": 225,
        "y": 660,
        "wires": [
                "49318b1c.5960f4"
        "type": "link out",
        "name": "Humidity",
        "links": [
            "a535b1aa.3022a"
        "x": 705,
        "y": 200,
        "wires": []
        "type": "comment",
        "name": "Workflow",
        "info": "",
        "x": 120,
        "y": 520,
        "wires": []
        "type": "comment",
        "info": "",
        "x": 160,
        "y": 580,
        "wires": []
        "type": "comment",
        "info": "",
        "x": 130,
        "y": 40,
        "wires": []
        "type": "comment",
        "info": "",
        "x": 160,
        "y": 240,
        "wires": []
        "serviceObj": {
        "pathObj": {
            "type": "float",
        "roundValues": "0",
        "x": 300,
        "y": 380,
        "wires": [
                "a54e7199.6374"
        "serviceObj": {
        "pathObj": {
            "type": "float",
        "x": 290,
        "y": 160,
        "wires": [
                "2e209753.9b4fb8"
        "type": "change",
        "name": "",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "true",
                "fromt": "bool",
                "to": "1",
                "tot": "num"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "false",
                "fromt": "bool",
                "to": "0",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 850,
        "y": 660,
        "wires": [
                "44d175d069852852",
                "f249379b.160858"
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "enum": {
                "0": "Open",
                "1": "Closed"
            "writable": true
        "initial": "",
        "x": 1180,
        "y": 660,
        "wires": []
        "serviceObj": {
        "pathObj": {
            "type": "enum",
            "enum": {
                "0": "Open",
                "1": "Closed"
        "initial": "",
        "x": 270,
        "y": 720,
        "wires": [
                "eb658cd1d02a864c"
        "id": "93a19e1ef0b5e34c",
        "type": "mqtt out",
        "name": "Relay 2",
        "topic": "Relay 2 State",
        "qos": "2",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 780,
        "y": 720,
        "wires": []
        "id": "eb658cd1d02a864c",
        "type": "rbe",
        "name": "Relay Message",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": false,
        "property": "payload",
        "topi": "1",
        "x": 480,
        "y": 720,
        "wires": [
                "93a19e1ef0b5e34c",
                "c552af5fabfc296d"
        "id": "c552af5fabfc296d",
        "type": "debug",
        "name": "debug 20",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 780,
        "y": 840,
        "wires": []
        "name": "SOLAR",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "keepalive": "60",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
