No VRM Feed in consumption on 3xMP2 (s99), Ekrano, ESS, VM-3P75CT and MPPTs
Hi All,
I have 1-2 little Problems,..
The first, might not be a problem, but it could be a reason or an result of the second problem, thats why i d like to mention
The Installation
-VM-3P75CT Grid meter, with parameter set as Grid meter connected with VE.Can
-External transfer switch conneted to MP2 Master
-3x MP2 5000/48/70
-3 MPPTs also VE.Can
-DIY Lithium VE.BMS
All in all, the configuration works fine, but,… two issues
  1. the AC loads during Feed-in are summing up, the feed in as well. Thats techniquly korrekt somehow, but not really, on the other hand. The real loads might be shown correctly, if the second issue is solved?
  2. The Grid meter “aktual” messurements r shown correctly,.. so during feed in with negative sign, but the VRM doent count the amounts in the statistics.
    that means, “to Grid” ist always 0
