I’m new here and relatively new to the Victron system.
My Setup:
3 Phase domestic house power 230V
EM24 on house power
1 Multiplus II (on L1)
Venus OS on Raspberry Pi
1 non Victron Solar Inverter 3 Phase - brought to the System by dbus-mqtt
1 non Victron Solar Inverter 1 Phase (on L1) - brought to the System by dbus-mqtt
My Problem:
The AC-Load calculation seems a “bit” off. For better understanding here is a picture.
While Loading the battery and producing Solarpower my AC-Load is calculated so it seems that I use all the power on L1. But the Solar Inverter over dbus-mqtt should report it on all 3 phases.
My Question:
Is this a limitation on Victron side and I have to upgrade on a 3 x Multiplus setup, or is there only a bug somewhere (in the dbus-mqtt?) which I should fix? Or did I misconfigure something?
I’m not sure but I believe it’s not a problem with dbus-mqtt or so.
Please give me a Hint
A huge thanks to you, jkoljo. I made a typo in my node red config and didn’t send the phases L1, L2 and L3, instead i send the phases K1, K2 and K3.
Thanks so much for this Hint!
Now I have only the problem, that the data is a bit flumsy in the current cloudy conditions because of the delay I have between the Inverter, converting and sending to the vrm.
But that’s a problem for another day.
P.S. How did you got this modern looking interface?
Happy to help! The new GUI was released with Venus OS v3.50:
It can be changed in the Cerbo user interface under Display & Appearance (at least in the new gui). You can also select in VRM if you want to use the classic or new GUI for remote console.
