New UI - setting temperature sensor scale bug still present in V3.60~80
The Remote Console New UI (v3.55) does not allow me to change the temperature sensor scale’s fractional part (the digit right of the decimal point). The “+” and “-“ buttons are only changing the integer part. I need to switch back to the old UI to be able to edit the fraction.
This looks like the same issue, but not under New UI category and without any response.
@Robinson The other thread you have posted on was in the DIY category rather than being placed in the correct beta test thread, which is how it was missed. I have swapped them to the beta test thread, this will now get visibility. Thanks for the sharp eyed report.
@mpvader This bug was never picked up in V3.50 series as the report was posted out of the way, someone else has dug it up again and I have confirmed it is still present in V3.60~80.
Noted! Thanks for the report!
