v3.53, the electric flow animation does not appear when the DC Loads is negative while it appears when it is positive, why? Is this normal?
Start a new topic after searching to see if anyone else reported the issue.
V3.52 is that the beta or public/normal release?
Sorry @lxonline
I didn’t intend to pollute your post, but I thought that on the contrary it was necessary to group the bugs under the same banner. Feel free to remove my question from this follow-up and create a new one if you feel that it is necessary.
To answer your question, I was in v3.50 normal and it was the same thing that’s why I applied v3.53 normal.
In add ition, I only see 3 out of 4 temperature readings from the Ethernet connection in “Levels” while when I am on the GX Touch all 4 appear. Weird!
I agree it is necessary to report issues. Not everyone sees or has them.
It helps to have each observation or problem separate so people vote on individual potential and current issues. Hence the instructions in the main post.
The post you replied on was specifically a beta test one. (Meant for the pre relase versions.)
yes I realized my mistake thank you for correcting that.
But you put it in the “beta testing” section while I’m talking about the official version v3.53 normal
Yeah. It has been moved it now that we clarified you are using normal release.
Thanks
