Dear community,
I would appreciate your advice regarding the correct way to connect a Victron MultiPlus II GX inverter to a residential installation.
As I understand, there are two possible wiring topologies for the neutral conductor.
Option 1 – Separated neutral buses (critical / non-critical loads)
- The incoming grid neutral is connected to the neutral busbar for non-critical loads.
This bus supplies loads such as the boiler, underfloor heating, air conditioners, etc. - The neutral for AC-IN of the inverter is taken from this same incoming neutral bus.
- The neutral from AC-OUT is connected to a second, separate neutral busbar.
All critical loads (heating boiler, circulation pump, etc.) are connected to this second neutral bus. - In the inverter settings, the ground relay is enabled to ensure correct operation of phase-dependent equipment (heating boiler and water pump).
Option 2 – Common neutral bus
- There is one common neutral busbar for the entire installation.
- All loads (critical and non-critical) are connected to this common neutral.
- The inverter AC-IN neutral is taken from this bus.
- The AC-OUT neutral is also returned to the same bus.
- In this configuration, the ground relay in the inverter settings is disabled.
With the Victron inverter, both configurations appear to operate correctly. However, many electricians strongly advise:
“Never switch or separate the neutral conductor.”
According to them, Option 2 is the correct approach.
I would kindly ask the community to explain, with technical reasoning, which connection topology is safer — both for equipment and for people.
Thank you very much for your advice.
Additionally, I would like to clarify the switching devices used in both configurations:
For switching between grid and inverter, a 2-pole changeover switch is used (for example, Hager SFT240).
In this case, both line (L) and neutral (N) conductors are switched.
For switching between grid and inverter, a 1-pole changeover switch is used (for example, Hager SFT140).
In this configuration, only the line (L) conductor is switched, while the neutral remains permanently connected (common neutral).
If helpful, I would also appreciate clarification on whether switching the neutral conductor (as in Option 1)
is recommended or discouraged when using a MultiPlus II GX in a residential TN system.
Thank you again for your support.
