I am wiring up a 3000W MP II in a 5th wheel camper.
For the AC out circuits, can I make a common Neutral bus (white wire), and tie that to my ground? Or should the neutral be isolated? Also, can I tie all AC Neutrals together AC out 1 and AC out 2 tied together with a common neutral bus?
Second question, would not do that also, keep it separate, could also lead to faults with breakers
OGPS
(Ed @ Off-Grid Power Systems - offgridps.com)
3
No and no. Your shore power connection will already have the N-G bond. Use the ground relay in the Multi to close the ground relay (N-G bond) when shore power isn’t connected. Inside the RV, leave all neutrals and grounds separate past the inverter. If you have a generator, make sure it has a N-G bond.
