I have had a problem, when my generator run (4KW Paguro VTE sincronous generator) Multiplus II doesn’t bypass, nor charge the battery, no alarm no message. Voltage & frequency was in range, so what to do ? After a lot of “googling” i found the solution, disable the UPS flag in Multiplus II configuration, in order do not check sinusoid waweform, all solved , now run perfectly. Not so easy manage Multiplus II configuration file, i do it in remote mode with CerboGX , modified with VEconfigure 3 and updated from remote consolle. Docs about this process are available from Victron. I hope this could be useful for others users.
Related topics
| Topic | Replies | Views | Activity | |
| Multiplus II not charging | 1 | 350 | 16 July 2025 | |
| Batterie mit Generator laden | 16 | 1111 | 17 November 2024 | |
| Multiplus is not charging from Shore Power | 6 | 155 | 6 January 2026 | |
| Multiplus II transfer switch | 1 | 216 | 14 December 2024 | |
| Multiplus II diable battery charging when AC1In active | 2 | 80 | 3 September 2025 |
