Hello everyone,
I’m having trouble understanding the charger logic of the MultiPlus II and Quattro when used with a Cerbo GX.
My main PV system consists of MPPT solar charge controllers and Quattros, a Cerbo GX, and a Pytes battery:
I then have a second system consisting of 3x MultiPlus II units and a Quattro (connected to a Cerbo GX via bus and USB), which are configured as chargers only:
No battery is “connected for communication” here; the systems are connected only on the DC side!
In the individual devices, you can set the charger parameters directly using VictronConnect:
How can I set the float voltage and charging current via Node-RED?
Depending on the main system’s battery state of charge or any surplus power on the grid, I want to charge the battery in addition to maintaining the float charge, or fully charge it.
I tried enabling DVCC on the Cerbo GX for the chargers, but that didn’t help. What am I missing?
