Cerbo with 3P Quattro + MultiPlus II as charger only
Hi all.
Trying to find in documentation but have a feeling it is not going to work. Asking experts here for an opinion.
We have a sistem with 3 x Quattros + Cerbo, now we want to fit two more MultiPlus’s as charger only in same setup. Quattros are Inverter Only.
Can all be setup on same Cerbo and do they show correct values or will Cerbo go: “what the x is going on?” :slight_smile:
Thank you and have a nice day fellow Victron friends!
You can connect a second system to the cerbo using an mk3.
There are obviously limitations.
You could use their remotes to switch them on and off like a generator if you are trying to maximise self consumption. Or find a way in node red.
Cool! No need to control them for now will do it by voltage. Will the charging Watts show in VRM of these two Multipluses? Just for end user to see what is happening..
For end user maybe add a shunt and a has dc system then. Otherwise there is no data in the overview.
Roger. Thanks for making it more clear now!
