Multiplus II + Lifepo4 + Switch to bulk
Hello. I have a 16 kWh LiFePO4 battery (with a JK BMS) connected to a Victron MultiPlus II 10,000 VA.
The problem I’m having is that in the morning, when the sun comes up and the Victron tries to switch to bulk charging to charge the battery, it starts the process and then stops… After a few seconds, it tries again and stops… It keeps doing this repeatedly. There are even slight flickers in the house lighting. What could be causing this problem?
Hello Baldric.
How is the Victron connected to the mains? Do you have a schematic or drawing of the connection, or has the problem already been resolved?
