How to correctly configure MultiPlus-II 48/5000/70-48 x3 L1,L2,L3 and two batteries Pylontech US5000
Hi follow these manuals:
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
If all steps are followed system setup is done!
One point: your battery capacity is too small for this setup
this is just for starters, more batteries will be purchased later ![]()
Yes thats possible, but remind its a battery based system, you could potentially have startup problems (inrush) when starting the multi’s
Youre probably fine, but just to help you prevent problems! ![]()
If you understand German, or use translate you can watch this video: https://www.youtube.com/watch?v=C6oqKursyko&list=WL&index=34&t=27s
@Ton_Gans thx ![]()
