Three standalone multiplus with one batterie each and VE.bus for 1 or 3-phase output
Hi!
Can anyone guide me, is this possible?
I´m trying to create a system were all multiplus can run individual givining AC 1-phase output, and on rare occasion 3-phase output.
In this setup I´m thinking that the capacity and age of the three different battery banks doesn´t matter, witch gives me a larger range of use.
Of course I understand that the smalest battery will be the limitation, running 3-phases.
Thanx in advance!
/Nils
To have a 3-phase system all MultiPlus have to be connected together and configured for 3-phase.
In this setup they should be connected to the same battery.
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
https://www.victronenergy.com/media/pg/The_Wiring_Unlimited_book/en/index-en.html
Dear El-Nisse
one battery in a 3 phase system means: put your three batteries in parallel to the multiplus system via a busbar (i.e. lynx power in)
In that configuration the battery with the lowest capacity does not limit the system. The three batteries act as “one”.
Have fun
Marc
Andy from the off-grid garage (youtube) shows this in his setup.
