I just received my MultiPlus II (10000/140/100) and after watching several videos on them, I was surprised to remove the cover and find threaded terminals on the AC connections - the same as the DC, instead of the green push connectors.
What’s the best way to connect in to these? - some kind of lugs?
I was going to use 16mm T&E (which has 6mm earth).
Is there a better recommendation for cable?
It’s for domestic use and to connect to a consumer unit (with a 40A RCBO for now, but wanted to over size the cable for future flexibility, hence the 16mm).
I know they are behind a cover, but they are remarkably open for live connections, once you remove the cover!
Thanks,
Ian
