I have a 3 phase genrator with 1 phase to the inverter charger by 15 amp lead.
The charger charges at max, 50 amps which is too much draw for the cable.
I need to lower it to say 40 amps to not cause so much heat.
I have a mk3 interface but don’t know how to use it.
Thanks
water_rat
(klim8skeptic)
2
Have a look at this video.
Thanks I can see where I have to go but it has a password on the bus.
I should be clearer it says contact your local dealer for a password.
And… I thought their maybe a backdoor password for the usb3.
Hope so thankyou
Try ZZZ or zzz, it is quoted many times on the site.
Charging 52 amps ac, from generator to charger.
The leads were melting but I did not know how to get into the bus to turn the amps down.
I thank this forum and you people as I am in and charging at 35 amps.
Its over 40c here so heat has a head start.
Cheers
Happy days.
Note: I am plowing
(coffee break right now) since 7 o’clock this morning to keep our driveway open.
