Multiplus 2: flashing "mains on"
Hi
I have a Multiplus 2, with LiFePO4 battery in ESS mode.
Nothing connected to AC out (yet).
All works fine and according to expectations. - AFAIK.
One “issue”. The “mains on” led is flashing often but not always.
I read in the manuals that “The device rejects the mains supply or is still synchronising.”
I have checked the mains voltage (~ 230V); Frequency is ~ 50Hz; Grid code is EN50549 (Europe) - I am located in the Netherlands.
Question: is this a real issue? What can I do about it?
Thanks, Hans
No. Probably have to read on :stuck_out_tongue: : if Mains & Inverter is flashing synchronous (And Bulk solid orange), that just means “energy feedin to ACIN during ESS Mode” :slight_smile:
The Victron Toolkit app has a interactive section for that :slight_smile:
No issue if the GX is not reporting any error.
Thanks…I did look for the answer, but I got always pointed to the AC Sync issues. Thanks again.
