What is sign wave chop? Something I can test and fix? Is it bad for the unit or my batts? This is my second unit that hums loudly and fan ticks. Drives me nuts.
Sorry bad English was used. The same sound is made when only half a sine wave is there such as when a triac based device is being used.
Checking the sine wave requires an oscilloscope.
The hum is normal for a transformer based inverter.
How comfortable are you with opening up the unit and checking that everything is plugged together well?
It’s a 50amp shore power cable. However, I am often using an adapter to a 110v outlet. If I recall correctly, the hum still persists when plugged into a 50amp or 30amp service.
I still dont think it is the fans.
Put the silence fans assistant on.
Obviously watch for heat.
Ticking can happen in power supply and transmit through for a large number of reasons.
