Multi RS without the battery + energy meter?
Hello.
I am considering using Multi RS as a AC Inverter for one instalation but there is a problem that we do not have Feed-In allowed to Grid.
In manual it states that if i enable mode without the battery it will automaticaly disable Energy meter support.
Does that mean that Zero feed-in will not work in this case ?
plz more infos to ur system… (parts)
Not built yet. But want to use Multi RS + VM-3P75CT and panels*.** I want to connect only AC In and have zero export to energy meter*
whitout a battery? victron is strong as an ESS with battery , but u need a GX (cerbro , venus or other) thats the brain of this system
Cerbo will be there as well . But yes without the battery for now.
I don’t think that control is possible at this stage.
It states that all PV energy will be exported and does not mention any curtailing functionality. Frequency shifting might work, but the manual does not mention it explicitly
In the Multi RS 6000 you can set maximum feed-in power, example 1000 watt or zero, haven’t try this, the function may even not working! (like my ESS setting)
think thats the wrong system for ur usage without battery…u lost many power at zero feed in and cant get it over night whitout a battery (best way : start with a BYD LV premium , this one is modular expandable and i have the same) easy to install and use
victron suports many other more…
All understandable . But it is more about timing. Can have this now and add battery before summer. Isnt that even Victrons selling pitch for new mode without battery?
Nevermind found article on Victron Professional.
No export limiting possible.
