Hi guys, i am using a multi 2 inverter charger for 24-volt batteries. Last summer I noticed that the charger was not charging in bulk mode. It was starting to charge but immediately was switching to absorption mode. The result was that the amps provided were low and unable to charge them. Since it’s a professional boat and there was no time for investigation, the electrologist recommended buying a new one. After installing it, was working great. Recently I noticed the same problem appeared. The batteries are in a good state. I updated the firmware from the application on my smartphone. Any ideas?
Related topics
| Topic | Replies | Views | Activity | |
| Installed Epoch 460 essential battery with multiplus 2 2x120 charging problem | 4 | 440 | 14 January 2025 | |
| Multiplus charger not charging | 5 | 510 | 13 May 2025 | |
| Multiplus 2 not charging my 300ah lead acid batteries | 5 | 67 | 22 May 2026 | |
| Inverter not charging batteries | 1 | 45 | 18 December 2025 | |
| Charging batteries using a microinverter | 0 | 78 | 10 October 2024 |
