Installed Epoch 460 essential battery with multiplus 2 2x120 charging problem
I am installing a system for my son. We have an Epoch 460 essential battery with a Multiplus 2 2x120 only using one leg.
We have gone thru the setting in the Multiplus for this battery everything looks right.
The inverter works fine but when plug into shore we have pass thru power but we can’t get it to go into charger mode.
We are using a GX digital multi control to control the system. When we switch to charger the light comes on for main but does not go into bulk or float on absorption. We have gone thru all the setting again and find nothing odd. I also unplug the GX and tried to use the switch on the Multiplus and got same results.
Any ideas ? Are we missing something? Is it possible something with the battery that needs to be changed?
What have you connected to the AC In?
The charger only works via L1 …
Thanks for responding
We connected to L1 in and we connected to L1 on the out also.
Thanks guys for replying and yes the MP works off grid as inverter.
The good news is we got it going didn’t figure out what the reason was but we went back to factory default setting and then re-set the battery charging requirements and boom it all started working. So some how there was something not set right in the beginning.
