Hi all,
I’m builing my venus os system on raspberry to upgrade my setup in my RV.
actually I have a MPPT 100/20 connected with a MPTT Display control.
could I have both display control and venusos connected to the MPPT 100/20?
is there some split cable? or some smart soltution?
No, you can only use one.
Thx for your reply,
So the only way I have is to develop a sort of bridge between the mppt dbus and the control display
Ok, after a quick test if I connect the mppt display control directly to the raspberry it remains off. So I tried to power with the RJ45 cable and connect the ve direct cable the mppt display control turns on but says disconnected.
It’s a good start I think!
Should be nice if victron can share the vreg specs for the display control in order to write a custom driver to send commands.
I will test as soon as possible
