good morning, I’m installing my first mp2 on the camper. Currently on the 220v input I have installed a voltage stabilizer because often the voltage that crowded structures provide is less than 220v (sometimes even 180v). installing the mp2 do I always need the stabilizer upstream or is this function native in the mp2? Thanks to everyone
The MP2 passes through whatever ac it is supplied with when hooked up to shorepower and if the inverter needs to supplement this it runs to the same voltage and frequency.
When there is no shorepower then it will run at 230V.
so if i find 180v, the mp2 will output 180v?
Yes, it’s NOT a double conversion equipment that could behave like a stabilizer.
so do you recommend to always keep the stabilizer separate upstream?
If you have a separate stabilizer, yes, always put it before MP2.
And to be convinced about the fact that the MP2 doesn’t have the possibility to behave like a stabilizer, take a look at its schematic from the manual. You can clearly see that there is a direct line between input and output.
