MP ii only with dess. Ess is ok. Load humm, light flickers, clickss
I have a problem that i do not understand.
When using ess all works fined but when i enable dyn. ess the system makes hard sounds (clicks and strong humm) and swiches of the invertor (invertor light goos out) but keeps running on grid It then starts again to do it all over.
Yesterday it workt perfectly.
When i shut off dess and the system stops delivering to grid it becones normal again.
The can be repeated.
No errors on cerbo or mail
Tested it now several times. Once i switch on dyn dns the system starts to do this
Lights flicker, a stong humming sound, clicks and then it is over for a few seconds
No heavy load in my house.
Firmware is 552.
This is something i can not solve.
Can anyone help?
More info.
Provider telles me they have installed a MSN.
In duch “middenspanningsnetwerk (MSN)-schakelapparaat of een automatische herinschakelaar (recloser).”
We had a blackout yesterday, and since that time the MP is going nuts.
According to the provider this device will automatically reconnect the grid 3 times in case of a short somewhere (outside the house. 1 fase is bad they say).
Had 3 times power down now, waiting for number 4. After number 4 grid will stay down privider says.
2 questions:
Does anyone know that such a device can make the MP go nuts.
Is it bad for the MP (listen to uploaded movie), or can i just keep the MP on?
I have it now on charger only, witch he seems to like better then inverting. But stll it has probkems every 10 minutes or do. But my house is now on the grid so my server goos down all the time.
Battery is 50%, thats good for 1.5 days. I try to get some juice into them. Tomorrow they will start working on it again and than i wand to switch the house back to invertor and disconnect the MP from grid.
