I have bought a 2nd hand inverter, but I don’t have it yet with me. I only know the SN: *10350300682*.
Can anyone tell me if I will have to source also a MK2 interface or will it work with my current MK3 interface (to read data) - connection to Venus OS ?
No reason for it not to work. Running Venus OS on a pi, I’m sure it will work with your Mk3, the Mk2 is slightly less capable that the 3, and I’m not sure if it’s still recognised by Venus os. I have an old Mk2 in my custom system, so if you have problems I can try this some time. In theory it should work with either. The Mk3 supports some VE commands that the Mk2 does not.
I received the inverter today. Opening the front plate I see this on the microprocessor:
1912132.HEX
I did not turn it on yet, I will do a pre charge first, as it seems the inverter is off for at least 2 years. So, I don’t know if it has been updated before or not. Most likely not. However, I would like to use a GX device to read data from it and send to VRM, will it work in such old version? Will I need to update?
