Hi can I use this phoenix multiplus with venusOS I was gifted it and I only have a 1600 multiplus ATM
Thank you all
Regards Paul
Wow, that still works? If I’m reading the serial correctly that’s an 18-year-old unit, which is pretty impressive.
I don’t believe that it could be connected to a Venus OS device, as it doesn’t appear to have VE.Bus ports - that RJ45 port on it is labeled “remote” rather than VE.Bus, so I’m doubtful. You could certainly give it a shot, but I’d tend to suspect a Digital Multi Control would be the most likely option to work in that port.
That appears to be the old microprocessor, so no it won’t work.
Is it possible to replace the main board and have the function
no, you need a newer unit.
Thought as much thanks anyhow
What I thought, but thanks for confirming
