Missing info in Quattro2 pdf manual
Haven’t used the qauttro 2 for a while and wanted to know what the particular switch positions are… but couldn’t find the right description in the pdf manual as well as the html page on the website, there info on the switch positions but not if it is position 1 or 2 or 0 :slight_smile: In the Multiplus manual there is a clear description.
for example a short quote of the manual:
3.1. On/Off/Charger Only Switch
When switched to ‘on’, the inverter/charger is fully functional. The inverter will come into operation, and the LED ‘inverter on’ will
light up.
An AC voltage connected to the ‘AC in’ terminal will be switched through to the ‘AC out’ terminal, if within specifications. The
inverter will switch off, the ‘mains on’ LED will light up, and the charger commences charging. The ‘bulk’, ‘absorption’ or ‘float’
LEDs will light up, depending on the charger mode.
This is in the manual:
But I would also say that it is pretty obvious.
As always I=ON and 0=OFF, so II=must be “charger only”
But I will also suggest that to the documentation team to review and maybe change that.
this is much clearer in the multiplus 2 GX manual:
5.1. On/Off/Charger only Switch
The switch is located on the underside to the bottom right of the product.
The switch has three positions. The centre position 0 is Off. The I position is On, and the II position is Charger Only.
When switched to ‘I / On’ (rocked towards the front of the unit), the product will come into operation and the inverter is fully functional.
danke
