Missing DESS prices and plan for tomorrow - and very high prices coming
Is it only my site missing prices and plan for tomorrow?
Problem is: very high prices all day are coming to Germany because no wind and no sun.
@dfaber
Here as well
same here …
Same here, Dutch energy company.
My home assistant has received new prices for tomorrow, VenusOS/DESS did not.
confirm, no price data in VRM for tomorrow … DE, BY.
Indeed very high prices expected tomorrow.
No prices in Transparency Platform, so not a Victron issue.
What API do you use to get the hourly electricity price in HomeAssistant?
Here the same, next energy is showing the prices… I give it some time otherwise will push the system to start charging later this evening.
EnergyZero integration
I will make a schedule from Home Assistant. Sub optimal, but it will work.
"That sounds like a smart solution! I don’t have Home Assistant myself, but it seems like something I’d be interested in. For now, I’ll be managing the charging manually, which is not ideal but works.
You can make a schedule in Victron as well. Dutch menu items (as I don’t know the English names for the menu items)
Remote console | ESS | Geplande laadniveaus | Schema X
“Scheduled charge levels” in English :slight_smile:
I’ve got my system set to (pre)charge from 23 to 7.
I can confirm this. Still no prices from Tibber in VRM as of now.
victron has been informed and has probably already sorted something out. If my information is correct, the problem will be resolved within the next hour
Unfortunately not a Victron issue.
If we’re lucky, somebody from Victron will copy/paste the prices from another source :slight_smile:
Prices are now available
"Thank you for the suggestion! I never looked at that option before, but it seems like a great tool as well for balancing the batteries.
There is a simpler solution for battery balancing:
VRM | Settings | Dynamic ESS | Battery | (Battery Balancing: On / Full Charge Interval: 14 days)
afbeelding
Also at Transparency Platform new prices available!
