Hello friends, I wish to know the best approach to measuring the production of 2, 240VAC PV Inverters without direct communication via rs485. I am aware I can set up energy meters to measure and integrate the data into my Victron VRM. However, I wish to know the best approach in accordance to the current system that I have. this is a diagram of my current system and connections, with my PV inverters on the AC-IN side of my dual Multiplus II 120/240VAC split phase setup.
I have installed as a grid meter the VM-3P75CT. I am wondering if I can use another one to measure the PV inverters. Can I use 1 to measure both outputs? Because these PV inverters are not generating a split phase, it is acting as a single phase 240VAC inverter connected to my main non-critical loads panel. What would be my best approach?
Any help or guidance will be greatly appreciated.
