Manually setting battery charge percentage on the Ekrano
Its probably coming from the VE bus. (Inverter soc.) Cant be set.
Set the battery monitor in system set up to the smart shunt you can manually set it there but the best way is to fuly charge the batteries so they synchronise and show us your settings on the shunt they probably need to be revisited.
