Good afternoon. My first post is about something i am still trying to understand after installing my 3 phase multiplus 48/5000, 4x pylontech 5000, CerboGX and ET340 net meter.
My house has 3x25A. It was previously 2 homes and a bakery shop. The prioperty is pretty large. 1 fase is used for each house.
I need the Victron system mainly for peak shaving because of electric car charging, heat pumps and further electrification
All fases have separate solar systems made with in total 6 different solar inverters.
In total there is 12050 watt peak solar panels.
On fase 1 the solar is 5740 wp on the ac2.
The other solar is on ac1 out. Both below 4000 wp
There are 2x goodwe, 1x sofar solar, 3x solar arrays with hoymiles micro inverters. All solar yield is monitored with 4x homewizzard kWh meters and 2x homewizzard plug.
In the cerbo the solar is not recognized.
The ess system seems to work properly using the et340 net meter (meter is directly at the grid input)
Do i need to make the solar visible for the ess to work properly?
Not all the solar connections are in the main cabinet. I have in total 3 separate fuse cabinets from the previously separated houses.
At this moment i am running dess trade mode. No problem in the winter but in the summer i like to try living off grid mode.
Any thoughts about this setup?
I am running venus 3.60 beta 8 without problems.
Hi if you want to make solar production visible you will need more energy meters configured as PV meters, ESS can measure them and they can be displayed on vrm
Also be carefull the 5740 Wp is too high for the 5k inverter, follow the victron 1:0 rule
@DuivertNL 1 know but then i need 6x et112 and some solar panels are about 50 meters away from the system. Going thru the yard, around the pool, crossing the house, opening the street… So running all those extra cables seems to big of a job (when not necessary)
@DuivertNL this solar inverter is about 8 meters away from the victron setup. So relatively easy it is only to buy the mppt replacing a perfectly working inverter. Than i have the input of 1700 wp from the total of 12.050 … So still not convinced of the benefits
When i try ess mode ( not dess ) and there is more solar than ac loads, the battery starts charging. The ess is trying to keep 0 at the meter and all solar yield is going to the battery. When in the evening there is more loads than solar the battery is used to keep 0 at the meter.
I don’t see any extra benefit of measuring the solar but everybody is saying you need the solar input visible for proper calculation… But what should be calculated?
For dess (green mode) i can understand the need to meter the solar yield but for std ess i am in doubt…
@victron what are the chances of implementing the homewizzard api in the official venus os on the cerbo GX?
I am measuring all my solar with homewizzard. Do i really need to buy 3x em24 meters for a total of more than 500 euros and than the next week you make the programming so the cerbo sees it for free …?
Hi Marc en Huib,
Ik zit met dezelfde vraag, is er ergens een script te vinden zodat de Cerbo de kWh meters van Homewizzard kan uitlezen. Ik heb twee solar systemen en ook al aangesloten op twee Homewizzard kWh meters. Dat functioneert allemaal goed.
ESS is 48 V 3000 watt plus 15 kWh LFP batterij.
Hoe kan ik de Cerbo van dit script voorzien?
Goedemorgen, ik heb de hoop opgegeven dat de data van Homewizzard beschikbaar komt voor de CerboGX. Ik heb geen programmeer ervaring voor node red en kan ook niemand vinden die dat voor me kan en wil doen.
Ik heb nu mijn ET340 vervangen door een VM-3P75CT en met de ET340 meet ik 3 van de 6 setjes zonnepanelen. Bij elkaar ietsje meer dan de helft van de totale opwek. Dit kon ik in de meterkast realiseren.
Het Dynamic ESS ziet nu in ieder geval zonnepanelen en rekent met de opbrengst ook al is het de helft.
Voor de andere 3 setjes moet ik flink lange kabels trekken en dure meters kopen dus ik kijk eerst hoe dit zich verhoudt als straks de opbrengst van de panelen meer is dan het gebruik per dag.
Wat ik ook merkte, als ik venus os large installeerde zelfs zonder ook maar iets met node red te doen dan werd de CerboGX meteen al flink zwaarder belast waardoor ik het gevoel kreeg dat hij vaak onbereikbaar of traag werd.
Hey, leuk dat je zo snel reageert!
Ik ga me als pensionado dan maar even op node-red storten. Zo moeilijk kan het toch ook weer niet zijn…?
Wel kwam ik op internet ene Marcel den Butter tegen die het al wel heeft opgelost. Volgens zijn facebook pagina (maar ik zit / wil niet op facebook…)
Zoekterm “Homewizzard kWh meter in VenusOS”
Zijn bedrijf heet Smartvolt. Heb hem gemaild maar hij wil of kan me niet helpen: geen tijd geen zin in “amateurs” . Hij verwijst mij door naar de diverse communities. Jammer, gemiste kans voor hem want volgens mij zijn er veel meer “amateurs” met deze vraag.
We houden contact.
Egenolf v SC
Ik hoop dat ze bij Victron meelezen.
Een hoop mensen zitten met soortgelijke problemen. De support is zelfs hier in het forum bedroevend. Er is eigenlijk maar 1 persoon van Victron die ik regelmatig zie reageren maar dan voornamelijk naar Duitsers.
