I’m using a Raspberry 4 with Venus OS and need to integrate a USB driver for the CH348 chipset installed in a “Waveshare USB TO 8CH TTL”. The driver must be compiled for Venus OS. But with the existing package manager I can’t get a kernel header for the current version:
opkg install linux-headers-5.10.110-rpi-venus-4
This causes me to get the error message during compilation:
make -C /lib/modules/5.10.110-rpi-venus-4/build M=/data/home/root/LINUX-2/driver
make[1]: *** /lib/modules/5.10.110-rpi-venus-4/build: No such file or directory. Stop.
make: *** [Makefile:7: default] Error 2
How can I install the current header for the 5.10.110-rpi-venus-4 or integrate a driver for the CH348 chipset into Venus OS ?
I’ve stumbled upon a similar problem: I’ve got the USB to TTL 8 channel board with the same chip : CH348, and I found out it needs to be cross-compiled then copy the compiled module and insert the driver module into kernel (insmod).
Did you already solved this problem ?
