This one is tricky…
For a special type of winter setup/shutdown, if a Lynx Smart BMS NG has its battery monitor (VE.Can) connected to a Victron Lithium NG battery (which is fully charged) but the BMS gets its voltage from a temporarily activated 230V charger acting as a power supply, is that a problem?
Will there be any conflict between the VE.Can measurement against a isolated not used voltage source and the real one temporarily supplying the BMS?
Or is the BMS just happy because the Lithium battery is charged, isolated and not used for the moment?
Löst!
