Subject: Incorrect BMS & SmartShunt Supplied for Victron Lithium NG Batteries
Hi All,
I’m writing regarding the Victron components supplied for my 24 V lithium system, specifically the BMS and monitoring equipment.
After reviewing Victron’s official documentation for the batteries supplied, I believe there has been a mistake in the BMS selection.
Batteries supplied
• **Victron Lithium NG 25.6 V 200 Ah**
Part number: BAT524120610 (x2)
BMS supplied
• **SmallBMS**
Part number: BMS400100000
Battery monitor supplied
• **SmartShunt 500 A**
Part number: SHU065150050
Issue identified
According to Victron Energy’s official documentation:
1\. **Victron Lithium NG batteries require a Lynx Smart BMS NG**
Victron states that the Lynx Smart BMS NG is mandatory and must be purchased separately for Lithium NG batteries.
The SmallBMS is not suitable for Lithium NG batteries used in inverter/charger systems.
2\. **The supplied SmallBMS is not compatible with my system**
My system includes:
• MultiPlus-II 24/5000 inverter/charger
• SmartSolar MPPT
• DC-DC chargers
• GX system (Cerbo GX)
Victron specifies that Lithium NG batteries in inverter-based systems must use a Lynx Smart BMS NG, which provides:
• High-current contactor
• Charge and load disconnect
• CAN-bus communication
• Full integration with GX devices
3\. **The SmartShunt is not required when using a Lynx Smart BMS NG**
The Lynx Smart BMS NG already provides:
• Current measurement
• State of charge (SOC)
• Battery protection
• Communication to Cerbo GX via CAN
In Victron’s recommended Lithium NG system designs, a SmartShunt is not used alongside a Lynx Smart BMS NG, as it becomes redundant and can cause duplicated or conflicting measurements.
Based on the above, I believe the correct configuration for my system should be a Lynx Smart BMS NG (500 A or 1000 A as appropriate) but before I bring this up with my supplier I would like some confirmation on my findings.
I look forward to hearing from anyone who has knowledge on the subject!
Stanley
