Lynx Shunt VE.CAN not visible to Cerbo GX
Just completed a new install of Multiplus-II 12/3000/120x2, Lynx Shunt, Lynx Distributor, SmartSolar MPPT 150/70 and Cerbo GX Mk2 in a motorhome using all Victron branded data cables. System works except the Cerbo GX does not see the Lynx Shunt as the battery monitor. Lynx Shunt and Cerbo GX are connected via Victron VE.CAN cable. Termination resistors are installed in the Lynx Shunt and the Cerbo GX.
Remote Console->Device List->Settings->System Setup->Battery Monitor is set to Automatic
Next line says: Auto selected: No battery monitor found
Remote Console->Device List->Settings->Services->VE.Can port->Network status shows the following:
State. ERROR -PASSIVE TEC: 128 REC:0
Bus off:0 Err passive:1 Bus warn: 1
RX packets:2 dropped:0 (0.00%)
overruns: 0 (0.00%) errors: 2 (100.0%)
TX packets:0 dropped:0
errors:0
So what’s going on? Help is appreciated. Thanks.
