Hey all, got my system all set up and turned on, though am having some issues with the monitoring through the Cerbo GX to display correctly. Here’s a summary:
3x EG4 LifePower4 Lithium Battery | 24V 200AH wired in parallel
Connected to Lynx Shunt, bolted to Lynx distributor
Connections on distributor are Victron MPPT CC for solar (not set up yet), DC appliances and Victron Multiplus II 24V 3000W 120V
Got the Cerbo GX with ve direct to CC (again, not hooked up yet), ve.bus to multiplus and ve.can to lynx shunt.
Here’s the issue, when I plug an extension cord from the house into my shore power connection with a 30 amp plug converter, the system stops showing any AC loads (displays 0) and is showing a negative load back to shore. The system looks to be working just fine as the batteries are charging and both DC and AC appliances work, but the display is all out of whack. Any suggestions on how to fix this so I can see an actual monitored input from the shore connection and both DC and AC output to my appliances? Pictures attached to show when shore power is plugged in and when it’s not. Thanks
