Can anyone explain or help why. I can see the Veh-Battery showing voltage when I login to the online. When I login to my Cerbo GX and edit my brief page level 1 and select Veh-Battery save then go to main screen it displays Veh-Battery -% Image below:
It is connected to Cerbo GX via USB
As you can see the line portal shows it
I have tested other items and they work fine. Thank you for reading this.
