Hi, it is never advised to update remote sites for this reason. There is always a risk of an issue.
It is unlikely that anyone will connect to your system remotely, it is somewhat beyond the purpose of this community and a Pi is a third-party monitoring device.
Sorry, just setting the right expectation.
Hope you get this resolved, often a power off/reboot can fix issues.
If it is online and shown on VRM as an active device, there is a reboot button at the bottom of the GX device entry.
@nickdb thanks for your input. The device has been running flawless for over 4 years, countless updates remotely, last one just refused to install, kept getting stuck at “installing 20%” on the progress bar so I gave up trying and it was working for several days after that.
There is no reboot button on vrm, I thought maybe someone from victron can go into it from their remote support tool as that says online.
If you can no longer reach the Raspberry via the remote console, then you’ll have no other option but to go there in person and take a look.
The memory card is one possibility; the power supply is another.
After the DC/DC converter for my Raspberry once burned out, I switched to the original GX devices. The price difference compared with a Raspberry with two isolated CAN adapters, Mk3 and a 48v DC supply isn’t that great. There’s also considerably less cable clutter.
