Hello all. Victron MPPT 150/45 with victron 500a shunt . I’m fully off the grid so it’s used regularly every day I have 3x renogy 100ah (Pro lite series)LiFeP04 in parallel on 12v system. . Basically I want some detailed values . How I should be configuring.. Basically at the moment I been running 14.2v-14.4v absorption and float 13.40v . . I’m after a complete list of values for each slot. It’s annoying the profile that I seem to have to put the values into, appear to be primarily setup for flooded. . Can I download another interface profile? Also with the shunt do I match its Values to the controller or do I put its full voltage slightly lower so it meets 100%.. thay are connected and are in communication with each other . Don’t seem to have any control over one another.. educate me please. .
Hi, have a look in the DIY section FAQ’s
There are topics for shunt inaccuracy that will help you improve your settings.
It’s a common challenge for people unfamiliar with the system.
