Venus OS, Kernel, Bluetooth, BLE, Development
Hi all,
I’ve been troubleshooting issues with certain Bluetooth LE peripherals (specifically some BMS units) failing to maintain a connection with the Cerbo GX / Venus OS.
The Symptoms:
The device connects via L2CAP, but almost immediately disconnects. dmesg shows the following error repeatedly: Bluetooth: hci1: unexpected SMP command 0x0b
The Root Cause:
This is caused by strict state handling in the Linux kernel’s BlueZ SMP implementation (net/bluetooth/smp.c). When a peripheral device initiates a Security Request (0x0b) after the connection is already established, the kernel rejects it if an SMP context exists, unless that specific command is already flagged as allowed.
The Fix:
I have successfully patched and built the Venus OS kernel (venus-6.12 branch) with a small modification to explicitly allow SMP_CMD_SECURITY_REQ even when an SMP context is active. This behavior aligns with other Bluetooth stacks (like Android’s Fluoride) and fixes the connection dropouts.
Code Change in net/bluetooth/smp.c:
// Function: smp_sig_channel
// Old:
if (smp && !test_and_clear_bit(code, &smp->allow_cmd))
goto drop;
// New:
if (smp && code != SMP_CMD_SECURITY_REQ && !test_and_clear_bit(code, &smp->allow_cmd))
goto drop;
Result:
With this kernel patch, my BLE devices now connect, pair, and communicate reliable without the “unexpected command” error.
I have generated a patch and can submit a Pull Request to the victronenergy/linux repo if this is of interest to the team. Has anyone else encountered this with newer BLE hardware?
Thanks!
