Victron Lithium Smart Battery - Howto re-enable BLE again
we just figure out how to re-enable a Smart Battery BLE (Bluetooth Low Energy) module.
Ref. to the Firmware Changelog …
v1.20-- 06 November 2020
  • Added ability to re-enable BLE again after it was disabled by the user.
    To re-enable BLE, a specific pin of the BLE module has to be connected to the module shield for 5 seconds.
    Note that the cover of the battery has to be opened to re-enable BLE. This can damage the battery housing. See the manual for more detailed information.
Ref. to the manual …
https://www.victronenergy.com/upload/documents/Lithium_Battery_Smart/15958-Manual_Lithium_Smart_Battery-pdf-en.pdf
(rev 21 - 01/2026) page 32
  • “6.3.1. Cannot connect with VictronConnect to the battery
    6. Has Bluetooth been disabled in the battery product settings?
    IMPORTANT: Disabling Bluetooth is an irreversible process. Once Bluetooth has been disabled, it can never be re-enabled.”
Manual is wrong at this point!
Firmware changelog is right.
After we remove the top cover, we see the BLE Chipset “MDBT42Q – 512KV2 (Chip Antenna)” and download the datasheet from https://www.raytac.com/ .
With a litte bit reverse engineering we figure out that there are two pins with no connections on the pcb (printed circuit board) and +3.3V.
P0.25 (2)
P0.26 (3)
The shield has GND level.
We still connect P0.25 (2) for five seconds to shield.
And voila, BLE Battery appears immediately in the VictronConnectApp. :slight_smile:
BLE was switched of since Feb. 2022 for IT security reasons.
Still upgrade firmware from v1.25 to v1.31.
Maybe we will install a little reset button for next BLE re-enable.
Links to old forum (community archive) entries with the same question …
