Vielen Dank für eure Antworten.
Ich ergänze meine Angaben:
- Raspberry 3B+ wird genutzt
- ich habe gestern ein Update auf VenusOS 3.42 gemachst
- VRM- den Neustart habe ich jetzt probeweise deaktiviert
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.110-rpi-venus-4 (oe-user@oe-host) (arm-ve-linux-gnueabi-gcc (GCC) 9.5.0, GNU ld (GNU Binutils) 2.34.0.20200910) #1 SMP Tue Sep 10 10:20:11 UTC 2024
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 2133 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s51916 r8192 d21812 u81920
[ 0.000000] pcpu-alloc: s51916 r8192 d21812 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 root=/dev/mmcblk0p3 rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 877720K/970752K available (10240K kernel code, 1333K rwdata, 3100K rodata, 1024K init, 885K bss, 27496K reserved, 65536K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 33798 entries in 100 pages
[ 0.000000] ftrace: allocated 100 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3b4/0x588 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000024] Switching to timer-based delay loop, resolution 52ns
[ 0.000324] Console: colour dummy device 80x30
[ 0.000388] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000422] pid_max: default: 32768 minimum: 301
[ 0.000628] LSM: Security Framework initializing
[ 0.000870] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000898] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002298] cgroup: Disabling memory control group subsystem
[ 0.002574] CPU: Testing write buffer coherency: ok
[ 0.003062] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004306] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004498] rcu: Hierarchical SRCU implementation.
[ 0.005619] smp: Bringing up secondary CPUs ...
[ 0.006772] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008039] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009261] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009429] smp: Brought up 1 node, 4 CPUs
[ 0.009470] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009487] CPU: All CPU(s) started in HYP mode.
[ 0.009503] CPU: Virtualization extensions available.
[ 0.010575] devtmpfs: initialized
[ 0.028583] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.028829] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.028864] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031905] pinctrl core: initialized pinctrl subsystem
[ 0.033088] NET: Registered protocol family 16
[ 0.037116] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.042792] audit: initializing netlink subsys (disabled)
[ 0.043096] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.043693] thermal_sys: Registered thermal governor 'step_wise'
[ 0.043926] cpuidle: using governor menu
[ 0.044681] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.044700] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.044989] Serial: AMBA PL011 UART driver
[ 0.066944] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080106] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:20:54, variant start
[ 0.090119] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[ 0.134802] Kprobes globally optimized
[ 0.137269] cryptd: max_cpu_qlen set to 1000
[ 0.140125] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.142382] SCSI subsystem initialized
[ 0.142634] usbcore: registered new interface driver usbfs
[ 0.142717] usbcore: registered new interface driver hub
[ 0.142795] usbcore: registered new device driver usb
[ 0.144683] clocksource: Switched to clocksource arch_sys_counter
[ 1.871075] VFS: Disk quotas dquot_6.6.0
[ 1.871213] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.871423] FS-Cache: Loaded
[ 1.871704] CacheFiles: Loaded
[ 1.871925] simple-framebuffer 3eaf0000.framebuffer: framebuffer at 0x3eaf0000, 0x10a800 bytes, mapped to 0x(ptrval)
[ 1.871950] simple-framebuffer 3eaf0000.framebuffer: format=a8r8g8b8, mode=656x416x32, linelength=2624
[ 1.876978] Console: switching to colour frame buffer device 82x26
[ 1.881484] simple-framebuffer 3eaf0000.framebuffer: fb0: simplefb registered!
[ 1.892695] NET: Registered protocol family 2
[ 1.892959] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.894943] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.895099] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.895225] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.895422] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.895599] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.895662] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.895944] NET: Registered protocol family 1
[ 1.896669] RPC: Registered named UNIX socket transport module.
[ 1.896688] RPC: Registered udp transport module.
[ 1.896705] RPC: Registered tcp transport module.
[ 1.896721] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.898361] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.903870] Initialise system trusted keyrings
[ 1.904118] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.913587] zbud: loaded
[ 1.915749] FS-Cache: Netfs 'nfs' registered for caching
[ 1.916636] NFS: Registering the id_resolver key type
[ 1.916684] Key type id_resolver registered
[ 1.916703] Key type id_legacy registered
[ 1.916855] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.916875] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.918201] Key type asymmetric registered
[ 1.918222] Asymmetric key parser 'x509' registered
[ 1.918284] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.918304] io scheduler mq-deadline registered
[ 1.918322] io scheduler kyber registered
[ 1.922059] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.926192] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 1.930237] Serial: 8250/16550 driver, 1 ports
[ 1.930272] Serial: 8250/16550 driver, ISA IRQ sharing enabled
[ 1.933021] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.933517] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.934802] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.947060] brd: module loaded
[ 1.958963] loop: module loaded
[ 1.960761] Loading iSCSI transport class v2.0-870.
[ 1.962592] usbcore: registered new interface driver lan78xx
[ 1.962682] usbcore: registered new interface driver smsc95xx
[ 1.962713] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.163336] Core Release: 2.80a
[ 2.163359] Setting default values for core params
[ 2.163391] Finished setting default values for core params
[ 2.363782] Using Buffer DMA mode
[ 2.363802] Periodic Transfer Interrupt Enhancement - disabled
[ 2.363819] Multiprocessor Interrupt Enhancement - disabled
[ 2.363837] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.363873] Dedicated Tx FIFOs mode
[ 2.364436]
[ 2.364456] WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
[ 2.364496] FIQ FSM acceleration enabled for :
[ 2.364496] Non-periodic Split Transactions
[ 2.364496] Periodic Split Transactions
[ 2.364496] High-Speed Isochronous Endpoints
[ 2.364496] Interrupt/Control Split Transaction hack enabled
[ 2.364518] dwc_otg: Microframe scheduler enabled
[ 2.364591]
[ 2.364601] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.364616]
[ 2.364625] WARN::hcd_init_fiq:458: FIQ ASM at 807f7168 length 36
[ 2.364639]
[ 2.364647] WARN::hcd_init_fiq:496: MPHI regs_base at bb810000
[ 2.364696] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.364741] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.364793] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.364852] Init: Port Power? op_state=1
[ 2.364868] Init: Power Port (0)
[ 2.365242] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.365266] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.365286] usb usb1: Product: DWC OTG Controller
[ 2.365305] usb usb1: Manufacturer: Linux 5.10.110-rpi-venus-4 dwc_otg_hcd
[ 2.365325] usb usb1: SerialNumber: 3f980000.usb
[ 2.366077] hub 1-0:1.0: USB hub found
[ 2.366161] hub 1-0:1.0: 1 port detected
[ 2.367402] dwc_otg: FIQ enabled
[ 2.367415] dwc_otg: NAK holdoff enabled
[ 2.367426] dwc_otg: FIQ split-transaction FSM enabled
[ 2.367443] Module dwc_common_port init
[ 2.368318] usbcore: registered new interface driver usb-storage
[ 2.368535] mousedev: PS/2 mouse device common for all mice
[ 2.369982] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.372726] sdhci: Secure Digital Host Controller Interface driver
[ 2.372744] sdhci: Copyright(c) Pierre Ossman
[ 2.373387] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.374066] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.374318] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.376357] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.376791] hid: raw HID events driver (C) Jiri Kosina
[ 2.376953] usbcore: registered new interface driver usbhid
[ 2.376970] usbhid: USB HID core driver
[ 2.381524] Initializing XFRM netlink socket
[ 2.382268] NET: Registered protocol family 10
[ 2.383674] Segment Routing with IPv6
[ 2.383787] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.384643] NET: Registered protocol family 17
[ 2.385048] Key type dns_resolver registered
[ 2.385618] Registering SWP/SWPB emulation handler
[ 2.389231] registered taskstats version 1
[ 2.389272] Loading compiled-in X.509 certificates
[ 2.390094] Key type ._fscrypt registered
[ 2.390114] Key type .fscrypt registered
[ 2.390132] Key type fscrypt-provisioning registered
[ 2.401500] uart-pl011 3f201000.serial: there is not valid maps for state default
[ 2.401723] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.401820] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.510715] printk: console [ttyAMA0] enabled
[ 3.515616] Indeed it is in host mode hprt0 = 00021501
[ 3.583667] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
[ 3.593730] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.602738] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.608794] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.641618] sdhost: log_buf @ (ptrval) (f7513000)
[ 3.682280] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.689487] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.696687] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.702234] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.711060] of_cfs_init
[ 3.713647] of_cfs_init: OK
[ 3.717629] uart-pl011 3f201000.serial: no DMA platform data
[ 3.723671] Waiting for root device /dev/mmcblk0p3...
[ 3.730732] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.736311] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.742919] Indeed it is in host mode hprt0 = 00001101
[ 3.842495] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.853574] mmc0: new high speed SDHC card at address 0001
[ 3.860208] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 3.867210] mmcblk0: p1 p2 p3 p4
[ 3.898769] mmc1: new high speed SDIO card at address 0001
[ 3.948324] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 3.956520] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 3.964275] devtmpfs: mounted
[ 3.976256] Freeing unused kernel memory: 1024K
[ 3.985095] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.993284] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.001221] hub 1-1:1.0: USB hub found
[ 4.005193] hub 1-1:1.0: 4 ports detected
[ 4.015249] Run /sbin/init as init process
[ 4.019350] with arguments:
[ 4.019362] /sbin/init
[ 4.019373] with environment:
[ 4.019384] HOME=/
[ 4.019395] TERM=linux
[ 4.324774] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.455165] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 4.463539] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.471921] hub 1-1.1:1.0: USB hub found
[ 4.476109] hub 1-1.1:1.0: 3 ports detected
[ 4.527945] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
[ 4.753872] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.779773] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 4.794772] usb 1-1.1.2: new full-speed USB device number 4 using dwc_otg
[ 4.952354] usb 1-1.1.2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 4.960966] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.968492] usb 1-1.1.2: Product: FT232R USB UART
[ 4.973204] usb 1-1.1.2: Manufacturer: FTDI
[ 4.977420] usb 1-1.1.2: SerialNumber: B0005YGP
[ 5.008049] udevd[165]: starting version 3.2.9
[ 5.051530] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.058934] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.065551] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.118589] udevd[166]: starting eudev-3.2.9
[ 5.284798] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[ 5.331066] mc: Linux media interface: v0.10
[ 5.335249] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.347744] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.354285] [vc_sm_connected_init]: start
[ 5.359383] [vc_sm_connected_init]: installed successfully
[ 5.415968] videodev: Linux video capture interface: v2.00
[ 5.425942] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 5.434572] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.546603] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.546825] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.571663] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.579432] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.608468] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.641349] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.661928] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.673601] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.686923] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.696088] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.704198] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.712134] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.721439] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.734599] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.739227] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 5.751079] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.769111] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.781876] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.788961] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.831371] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 5.841886] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 5.848835] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.851252] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.867404] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.873754] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 5.886533] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 5.895615] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 5.914833] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 5.934805] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.942363] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.997643] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.997821] usbcore: registered new interface driver usbserial_generic
[ 6.012816] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.022419] usbserial: USB Serial support registered for generic
[ 6.035058] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.075774] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 6.081325] usbcore: registered new interface driver ftdi_sio
[ 6.087889] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.098885] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 6.109802] ftdi_sio 1-1.1.2:1.0: FTDI USB Serial Device converter detected
[ 6.117703] usb 1-1.1.2: Detected FT232RL
[ 6.123717] usb 1-1.1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 6.139409] random: crng init done
[ 6.142830] random: 2 urandom warning(s) missed due to ratelimiting
[ 6.192826] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.235107] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.248766] usbcore: registered new interface driver brcmfmac
[ 6.547649] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.556849] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 6.575162] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 6.926815] Bluetooth: Core ver 2.22
[ 6.930552] NET: Registered protocol family 31
[ 6.935033] Bluetooth: HCI device and connection manager initialized
[ 6.941412] Bluetooth: HCI socket layer initialized
[ 6.946321] Bluetooth: L2CAP socket layer initialized
[ 6.951402] Bluetooth: SCO socket layer initialized
[ 6.967836] Bluetooth: HCI UART driver ver 2.3
[ 6.972305] Bluetooth: HCI UART protocol H4 registered
[ 6.977591] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 6.984140] Bluetooth: HCI UART protocol Broadcom registered
[ 7.146149] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
[ 9.102507] watchdog: watchdog0: watchdog did not stop!
[ 10.254952] NET: Registered protocol family 38
[ 11.567675] device eth0 entered promiscuous mode
[ 11.916823] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 15.351586] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.707551] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 33.763564] cam-dummy-reg: disabling
[16279.878780] Bluetooth: hci0: Frame reassembly failed (-84)
[16279.878791] Bluetooth: hci0: ACL packet for unknown connection handle 0
[16279.892371] Bluetooth: hci0: Frame reassembly failed (-84)
[16279.932679] Bluetooth: Unexpected start frame (len 26)
[18380.148268] Bluetooth: hci0: Frame reassembly failed (-90)
[18380.154437] Bluetooth: hci0: Frame reassembly failed (-84)
[23104.845810] Bluetooth: hci0: Frame reassembly failed (-90)
[23104.851491] Bluetooth: hci0: Frame reassembly failed (-84)
[31349.909832] Bluetooth: hci0: Frame reassembly failed (-90)
[31349.915486] Bluetooth: hci0: Frame reassembly failed (-84)
[31403.701996] Bluetooth: hci0: Frame reassembly failed (-84)
[31403.702048] Bluetooth: hci0: ACL packet for unknown connection handle 0
[31403.707510] Bluetooth: hci0: Frame reassembly failed (-84)
[31403.799267] Bluetooth: Unexpected start frame (len 26)
[31403.804577] Bluetooth: hci0: Frame reassembly failed (-90)
[31403.855531] Bluetooth: Unexpected start frame (len 26)
[31404.963355] Bluetooth: hci0: Frame reassembly failed (-84)
[31404.963560] Bluetooth: hci0: ACL packet for unknown connection handle 0
[31404.968890] Bluetooth: hci0: Frame reassembly failed (-84)
[31404.968904] Bluetooth: hci0: Frame reassembly failed (-84)
[31404.968926] Bluetooth: hci0: Frame reassembly failed (-84)
[31405.018054] Bluetooth: Unexpected start frame (len 26)
[51066.768476] Bluetooth: hci0: unexpected event for opcode 0x2016
[59343.010828] Bluetooth: hci0: Frame reassembly failed (-84)
[59343.010925] Bluetooth: hci0: ACL packet for unknown connection handle 0
[59343.016554] Bluetooth: hci0: Frame reassembly failed (-90)
[59343.048308] Bluetooth: Unexpected start frame (len 26)
[60516.685097] Bluetooth: hci0: Frame reassembly failed (-90)
[60516.690672] Bluetooth: hci0: Frame reassembly failed (-84)
[60834.001792] Bluetooth: hci0: Frame reassembly failed (-84)
[60834.007326] Bluetooth: hci0: Frame reassembly failed (-84)
[60834.057172] Bluetooth: Unexpected start frame (len 26)
[62209.200924] potentially unexpected fatal signal 11.
[62209.205835] CPU: 1 PID: 4751 Comm: python Tainted: G C 5.10.110-rpi-venus-4 #1
[62209.214423] Hardware name: BCM2835
[62209.217853] PC is at 0x76b36308
[62209.221044] LR is at 0x76b369a8
[62209.224208] pc : [<76b36308>] lr : [<76b369a8>] psr: 20000010
[62209.230487] sp : 7e95a300 ip : 0114936e fp : 00000000
[62209.235825] r10: 00000000 r9 : 0115ae2c r8 : 0115b0f0
[62209.241122] r7 : 00000010 r6 : 01151be8 r5 : 7e95a3d0 r4 : 00000000
[62209.247665] r3 : 00000010 r2 : 00000000 r1 : 0115ae28 r0 : 00000010
[62209.254256] Flags: nzCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
[62209.261529] Control: 10c5383d Table: 0a35406a DAC: 00000055
[62209.267295] CPU: 1 PID: 4751 Comm: python Tainted: G C 5.10.110-rpi-venus-4 #1
[62209.275817] Hardware name: BCM2835
[62209.279216] Backtrace:
[62209.281683] [<80a85b80>] (dump_backtrace) from [<80a85ef0>] (show_stack+0x20/0x24)
[62209.289257] r7:ffffffff r6:00000000 r5:60000113 r4:810e88f0
[62209.294924] [<80a85ed0>] (show_stack) from [<80a8a2e4>] (dump_stack+0xc8/0xf4)
[62209.302156] [<80a8a21c>] (dump_stack) from [<80108ba4>] (show_regs+0x1c/0x20)
[62209.309301] r10:fffffe30 r9:83f51f58 r8:00000f00 r7:0000000a r6:89c09f80 r5:83f50000
[62209.317133] r4:83f51fb0 r3:e7a42bf2
[62209.320720] [<80108b88>] (show_regs) from [<8013a1ec>] (get_signal+0x9fc/0xa00)
[62209.328041] [<801397f0>] (get_signal) from [<8010b6c8>] (do_work_pending+0x15c/0x568)
[62209.335883] r10:fffffe30 r9:5ac3c35a r8:83f51fb0 r7:00000001 r6:83f51f44 r5:83f51f28
[62209.343714] r4:ffffe000
[62209.346257] [<8010b56c>] (do_work_pending) from [<80100074>] (slow_work_pending+0xc/0x20)
[62209.354435] Exception stack(0x83f51fb0 to 0x83f51ff8)
[62209.359490] 1fa0: 00000010 0115ae28 00000000 00000010
[62209.367672] 1fc0: 00000000 7e95a3d0 01151be8 00000010 0115b0f0 0115ae2c 00000000 00000000
[62209.375854] 1fe0: 0114936e 7e95a300 76b369a8 76b36308 20000010 ffffffff
[62209.382477] r10:00000000 r9:83f50000 r8:00000000 r7:10c5383d r6:ffffffff r5:20000010
[62209.390308] r4:76b36308
[66167.570701] potentially unexpected fatal signal 11.
[66167.575684] CPU: 3 PID: 10772 Comm: python Tainted: G C 5.10.110-rpi-venus-4 #1
[66167.584408] Hardware name: BCM2835
[66167.587845] PC is at 0x76b3d308
[66167.591032] LR is at 0x76b3d9a8
[66167.594222] pc : [<76b3d308>] lr : [<76b3d9a8>] psr: 20000010
[66167.600514] sp : 7ee8a300 ip : 0096e45e fp : 00000000
[66167.605841] r10: 00000000 r9 : 0097d7ec r8 : 008fc5c0
[66167.611113] r7 : 00000010 r6 : 0097e800 r5 : 7ee8a3d0 r4 : 00000000
[66167.617683] r3 : 00000010 r2 : 00000000 r1 : 0097d7e8 r0 : 00000010
[66167.624304] Flags: nzCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
[66167.631594] Control: 10c5383d Table: 0159c06a DAC: 00000055
[66167.637365] CPU: 3 PID: 10772 Comm: python Tainted: G C 5.10.110-rpi-venus-4 #1
[66167.645978] Hardware name: BCM2835
[66167.649380] Backtrace:
[66167.651858] [<80a85b80>] (dump_backtrace) from [<80a85ef0>] (show_stack+0x20/0x24)
[66167.659438] r7:ffffffff r6:00000000 r5:60000113 r4:810e88f0
[66167.665108] [<80a85ed0>] (show_stack) from [<80a8a2e4>] (dump_stack+0xc8/0xf4)
[66167.672345] [<80a8a21c>] (dump_stack) from [<80108ba4>] (show_regs+0x1c/0x20)
[66167.679490] r10:fffffe30 r9:88fdbf58 r8:00000f00 r7:0000000a r6:89c09500 r5:88fda000
[66167.687321] r4:88fdbfb0 r3:37f39d2c
[66167.690908] [<80108b88>] (show_regs) from [<8013a1ec>] (get_signal+0x9fc/0xa00)
[66167.698228] [<801397f0>] (get_signal) from [<8010b6c8>] (do_work_pending+0x15c/0x568)
[66167.706067] r10:fffffe30 r9:5ac3c35a r8:88fdbfb0 r7:00000001 r6:88fdbf44 r5:88fdbf28
[66167.713898] r4:ffffe000
[66167.716441] [<8010b56c>] (do_work_pending) from [<80100074>] (slow_work_pending+0xc/0x20)
[66167.724621] Exception stack(0x88fdbfb0 to 0x88fdbff8)
[66167.729675] bfa0: 00000010 0097d7e8 00000000 00000010
[66167.737860] bfc0: 00000000 7ee8a3d0 0097e800 00000010 008fc5c0 0097d7ec 00000000 00000000
[66167.746042] bfe0: 0096e45e 7ee8a300 76b3d9a8 76b3d308 20000010 ffffffff
[66167.752664] r10:00000000 r9:88fda000 r8:00000000 r7:10c5383d r6:ffffffff r5:20000010
[66167.760493] r4:76b3d308
[68242.840906] Bluetooth: hci0: Frame reassembly failed (-90)
[68242.846428] Bluetooth: hci0: Frame reassembly failed (-84)
[68242.893770] Bluetooth: Unexpected start frame (len 26)
[68538.909114] Bluetooth: hci0: Frame reassembly failed (-90)
[68538.915022] Bluetooth: hci0: Frame reassembly failed (-90)
[70744.708754] Bluetooth: hci0: Frame reassembly failed (-90)
[70744.714762] Bluetooth: hci0: Frame reassembly failed (-84)
[77598.614072] Bluetooth: hci0: Frame reassembly failed (-84)
[77598.619616] Bluetooth: hci0: Received unexpected HCI Event 00000000
[77598.626129] Bluetooth: hci0: Frame reassembly failed (-84)
[78907.783245] Bluetooth: hci0: unexpected event for opcode 0x200c
[79808.757368] Bluetooth: hci0: unexpected event for opcode 0x2016
Fehlerspeicher:
Oct 4 12:46:22 raspberrypi2 daemon.warn bluetoothd[28241]: ../bluez-5.55/src/main.c:parse_controller_config() Key file does not have group “Controller”
Oct 4 12:46:22 raspberrypi2 daemon.info bluetoothd[28241]: Bluetooth management interface 1.18 initialized
Oct 4 12:46:26 raspberrypi2 daemon.info bluetoothd[28241]: Terminating
Oct 4 12:46:26 raspberrypi2 daemon.info bluetoothd[28241]: Exit
Oct 4 12:46:28 raspberrypi2 daemon.info bluetoothd[28271]: Bluetooth daemon 5.55
Oct 4 12:46:28 raspberrypi2 daemon.warn bluetoothd[28271]: ../bluez-5.55/src/main.c:parse_controller_config() Key file does not have group “Controller”
Oct 4 12:46:28 raspberrypi2 daemon.info bluetoothd[28271]: Bluetooth management interface 1.18 initialized
Oct 4 12:46:56 raspberrypi2 daemon.info bluetoothd[28271]: Terminating
Oct 4 12:46:56 raspberrypi2 daemon.info bluetoothd[28271]: Exit
Oct 4 12:46:58 raspberrypi2 daemon.info bluetoothd[28446]: Bluetooth daemon 5.55
Oct 4 12:46:58 raspberrypi2 daemon.warn bluetoothd[28446]: ../bluez-5.55/src/main.c:parse_controller_config() Key file does not have group “Controller”
Oct 4 12:46:58 raspberrypi2 daemon.info bluetoothd[28446]: Bluetooth management interface 1.18 initialized
Oct 4 12:47:01 raspberrypi2 daemon.info bluetoothd[28446]: Terminating
Oct 4 12:47:01 raspberrypi2 daemon.info bluetoothd[28446]: Exit
Oct 4 12:47:03 raspberrypi2 daemon.info bluetoothd[28481]: Bluetooth daemon 5.55
Oct 4 12:47:03 raspberrypi2 daemon.warn bluetoothd[28481]: ../bluez-5.55/src/main.c:parse_controller_config() Key file does not have group “Controller”
Oct 4 12:47:03 raspberrypi2 daemon.info bluetoothd[28481]: Bluetooth management interface 1.18 initialized
Das das Keyfile nicht zur Gruppe Controller gehört, kann man lt. Internetsuche wohl vernachlässigen.
Bluetooth: hci0: Frame reassembly failed (-84)…dies ist wohl ein bekanntes Problem, welches angeblich in bestimmten Kernelrevisionen gelöst wurde, nur bei VenusOS bin ich darauf angewiesen, was in den jeweiligen Versionen bereits kompiliert wurde und kann daher nichts ändern.
Das Problem ist, dass die Verbindung zum Bluetooth Verbindung zum JKBMS öfters ausfällst und VenusOS deshalb die Victron Laderegler deaktiviert. Kann ich diese Deaktivierung vorübergehend abstellen?
