Jumper link, remove or leave?
The jumper link on my charger is set at conventional algorithm. (1-2)
What does this do.
I have the App on my phone and have adjusted some “basic” settings for charge and float to match my battery specifications.
I have not gone into the “expert” area as I have no real need.
Do I remove the jumper link or just leave it on?
What does the jumper link do?
Please don’t refer me to the manual, I have read it several times and still don’t understand what it means.
Is the link only for the load terminals on the charger or does it have some other effect on other settings?
Thanking you in advance.
Can you specify which part of the jumper link-specific section of the manual isn’t clear to you? I know Victron is always making an effort to simplify their manuals.
The jumper link only affects the load output behavior, that is its only purpose. How it affects it is described -with photos- in the above-linked section of the manual. If you’re not using the load output, you don’t need to worry about it at all. If you’re using the app to program the load output, then -as the manual states- remove the link.
Thank you for your help.
I don’t use the LOAD at the moment, but may later, so Ill just leave it where it is.
As for the link information,
Its a little confusing in the instructions where it tells you that if you use the app to configure LOAD setting you must remove the link.
But it would be better to describe up front before that what the LOAD means.
I thought it meant the battery settings.
Again, Thank you.
