Issues with node-RED proxy relays from VRM
I have a specific installation (v3.62) that takes forever to connect to the node-red proxy as advertised by the VRM, i.e. when I try to access it through the VRM (“Venus OS Large” menu). Sometimes the connection completely times-out. Both the node-RED editor and the node-RED Dashboard do this.
Everything else Victron-specific or otherwise network-related is working fine, it’s just the node-RED stuff that do this.
I have restarted the Cerbo, with no luck. Is there anything else I can try, to make things better? It used to work fine, a few days ago.
