I have a Cerbo GX and MultiPlus II 120v 48/5000/70-95 - specs here if that isn’t specific enough: https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-II-120V-EN.pdf
I have a small PV inverter and I would like to get its production measurements into victron world and ESS. It’s single phase.
I have a VM-3P75CT meter elsewhere in the system and I know it would work well, but I am wondering if it can be done less expensive.
I see victron has this AC current sensor that is single phase, more than enough amperage, and much less expensive. I am wondering if it will work. Sensor webpage here: https://www.victronenergy.com/meters-and-sensors/ac-current-sensor
The sensors compatibility list does not mention my MultiPlus. Is it not compatible, or is the MultiPlus II I have just newer than the sensor documentation? Current sensor documentation and compatibility list here:
https://www.victronenergy.com/live/ac_current_sensor:start
