I have reinstalled my router. I want to reconnect the Cerbo GX via the LAN Ethernet cable, but I get not access to the menu. I tried http://venus.local, this does not work. I need the IP Address to access the router. Bluetooth is disabled for security reasons. What do I need to do to access the Cerbo GX? Lex Netherlands.
Try VictronConnect with a device that is connected to the same network.
If I remember correctly there is also a button at the Cerbo enable/disable Bluetooth/the WiFi access point.
Problem solved. I had connected the Cerbo Gx directly to the notebook; stupid, that obviously doesn’t work. Now connected via the router again and it works again. I wish you a pleasant day. Lex Netherlands
