I have big problem putting boat in danger. I have cerbo GX, Victor LTE, Wifi on connected to 5G Routher and ethernet cable to switch connected to raymarine for the past months it has been going crazy. cerbo loses connection to itnernet the moment I turn on raymarine with a different IP address on ethernet switch. it has alwasy worked what happens now is that both LTE and WIfi via router get bypassed by the IP address of the raymarine network. once I turn off raymarine victorn has hard time reconnect to internet and VRM. I lose connection and most importantly location and geofence of the sailing boat. can someone help what is going on maybe I need to factory reset cerbo? i have 3.67 cergo and 4.19 raymarine axiom MFD
Is the Ethernet only used for local device comms not internet?
If so, this is well documented, the gateway for the network must be 0.0.0.0
thanks so much so shall I put manual IP address? before it was automatic for a long time. if I put manual shall I assign IP address or onlu change the gateway? I will try again but I think I did remotely change to 0.0.0.0 and lost connection few hours ago.
Just try changing the gateway on the wired interface
I will do it tomorrow wheh I go back to the boat to access the gateway I need to switch from automatic to manual correct? in that case I need to put also a IP address and a subnet mask. this is what I tried to to remotely and the system broke. I mean change gateway to 0.0.0.0 while leaveing the rest untouched
problem fixed I did first automatic Address then change to manual left everything from the automatic setting namely the IP and Subnet mask taht rayumarine with the switch gave to victron and than change gateway to 0.0.0.0
Glad it’s fixed.
